11-07-2010, 06:01 PM
2011 25' FB Flying Cloud
West Linn
Inverter to run refer while driving...
Ok, so we're not big fans of having the refer run on gas while driving down the road, so I'm looking into using an inverter to run the refer/freezer off the 12volt system.
So while installing an inverter to run the refer is easy enough, does anyone know what will happen to the charge level of the AS batteries? I don't really know what our TV(a Tundra) will do when it's own battery is charged after driving awhile.
I've looked into inverters and the like, but haven't really found any info on this specific situation, so any help would be appreciated. We've just picked up our new AS, after a brief stint in the Class B world. Our refer there ran on 12v, so we've kinda been used to that.
Jeff
11-07-2010, 06:15 PM
Naples
Solar would help a bit, but you really need a much larger battery battery bank and a way to keep them charged to do what you want. Another avenue would be to replace your Dometic fridge with a marine unit that uses a Danfoss compressor and will run on either 120VAC or 12VDC, which ever is present. They are very efficient and draw only 3-4 amps DC while running. I'm waiting for my Norcold to die (should be any day now) and I will be replacing it with a marine unit.
Jeff
Jeff,
You will need a very large battery bank to run your refer on AC thru an inverter. The elements in a Dometic fridge your size draws about 120watts AC. That becomes 1200 watts DC which is 120amps that will be drawn every hour. Even if the element is active only 50% of the time, you will still require 60 amps/hour not even factoring in the inefficiencies of the inverter. Even the best run at 85%, so add another 15% to 60 and you get almost 70 amps DC/hour. Electric heating elements really burn up DC power in an RV.
Assuming that you have the stock Interstate group 24 batteries (160 amp/hours for the pair), you could run your refer thru the inverter for less than an hour before you reach the 50% discharge level on your batteries. Your TV will NOT recharge these batteries at that rate, and may give you another half to one hour of run time.
These refers are designed to run on LP WHILE TRAVELING. Many, many folks (including myself) run the refer on LP while on the road with NO consequences, other than cold beer when you stop for the night.
If you really don't want to use LP, you can cool it to temp on electric while connected and then pack some dry ice into the refer and freezer box and keep it closed until you reach your destination, when you can hook up to 120VAC. This really converts your refer to a big cooler.
Just remember that for every minute you keep that refer door open, an RV fridge requires ONE HOUR of run time to recover the lost chill in the box.
lewster
11-07-2010, 06:16 PM
Airstream Rescue
1948 22' Liner
1966 20' Globetrotter
Wimberley
The alternator in your TV should be able to provide sufficient current to operater the refrigertor through and maintain charge on both TV and Airstream batteries. I have done this on earlier Airstream with no problem. You will need to provide a transfer switch to transfer refrigerator from normal AC power feed to inverter and back again. Good Luck
11-07-2010, 06:19 PM
1996 30' Excella
La Pine
12v dc or 120v ac
Jeff,
Is your refer a 2-way (lpg-120v ac) or 3-way (lpg-120v ac-12v dc)? If you run it on either 12v dc or go through an inverter (NOT CONVERTER) it will take batteries down fairly quick. We run ours on lpg while driving and while dry camping and use 120v when we have hookups. We've done this for years without any problems even while fueling (biggest concern). Quite a few gas stations post requirements about turning all lpg pilot lights off prior to fueling. It's your call as to what your comfort level is. Gary
11-07-2010, 06:25 PM
Naples
Another option is the AC/DC marine fridge that uses a Danfoss compressor. These are very efficient units that draw only 3-4 amps DC when running. They can operate 30* off level and because they use a compressor, they really get your box down to 34* quickly and keep it there! Ahhhhh, COLD beer for a change and HARD ICE CREAM!!!!!
I will be replacing the aging Norcold in my MoHo with one of these units very soon. They have more interior space than a standard RV fridge, and will switch automatically to either AC or DC (which ever is present) with a priority on AC if it is present.
lewster
11-07-2010, 06:26 PM
1984 31' Airstream310
Ajo
Dometic quit making three-way refrigerators years ago because of (A) Improved design that would enable propane during running and (B) So many folks ran their batteries down by forgetting to switch them over when stopping at a hook-up campground. Our Dometic switches over automatically when it senses shore power.
11-07-2010, 06:31 PM
Airstream Rescue
1948 22' Liner
Wimberley
If your refrigerator operates at 120Watts at 120 volts AC It will also operate at approximately 120 Watts at 12 Volt DC. It will draw approximately one amp at 120 volts AC and 10 amps at 12 Vots DC.
11-07-2010, 06:58 PM
West Linn
Thanks everyone, good info and suggestions. I know most people travel with the gas on, but some states don't allow this and if you're on a ferry, it must be shut off.
According to the label, the refer draws 2.7 amps, so 324 watts AC. I also found some info that says the Tundra provides 12 constantly at the plug. So I'm thinking this should work fine, as our only goal is to run on 12v when driving. It appears that some inverters have automatic transfer switches, so when we plug-in, that should solve the memory issue(switching to AC).
On another note, the refer has a function that when you shut off the truck, the gas and spark are shut off for 15min, such as at a gas station. Ours is not connected, has anyone connected this?
Jeff
11-07-2010, 09:22 PM
1966 24' Tradewind
1995 34' Excella
Lynchburg
Jeff
I have tried operating my refrigerator while driving using a 400 watt invertor. It worked fine for about an hour, but then the battery was down too low in voltage to operate the refrigerator. My refrigerator draws 180 watts or 15 amps, so it is a significant load. I have a Tundra with a 150 amp alternator. However the charge line to the trailer, I believe, is limited to only 5 amps. So with 5 amps to the trailer and 15 amps to the frig, it is just a matter of time before your battery voltage is too low.
There has got to be a way to get around the 5 amp charge rate to the trailer.
It also helps to make sure your frig is completely cold before your trip and we carry a one gallon container of water frozen to keep the frig from running. Like Lew suggested, you could carry some dry ice too.
I jumped thru these hoops when my frig was not working on LP. It works on LP now, so I just run it on LP when we are driving. I don't have a safety problem with it.
Dan
11-07-2010, 09:59 PM
2006 19' Safari SE
Tucson
There's no doubt a way to do this, but I have to go with those who run the frig on LP while towing...it's simpler, it's faster...and your newer frig is designed to be operated that way. We have done it for years and have never had an issue or a worry...in this trailer or in a small motor home we had before the AS. If it makes you feel more comfortable, just go inside and turn off the frig when you are pumping gas, then turn it back on after you pull away from the pumps...
TB & Greg and Abbey Schnauzer
AirForums #21900
PastPrez, 4CU/WBCCI
11-07-2010, 11:04 PM
1978 28' Ambassador
Morada
Our 2001 Lance TC had a large 3-way refer in it, and we ran it on the 12 volt mode when on the road...
I wired a constant duty relay from the alternator output directly back to the 12 volt power terminal on the camper harness - I used 6 gauge wire in hopes of keeping voltage loss at a minimum...
We never had any discharged battery issues with this set up - just had to remember to turn to gas mode when stopped - it would auto change to AC when plugged into shore power, of course...
The 12 volt TC wiring was much shorter in length than wiring required to run back to a TT, so I'm not sure it would really be an acceptable option without lots of rewiring, etc...
Ray
Ray & Pat; Morada, CA
11-08-2010, 08:47 AM
West Linn
Originally Posted by TouringDan
Jeff
Dan
Okay, this is what I was concerned about, not having the current to carry the full load of the refer. So it sounds like it's LP unless I rewire the truck!
So the question remains, what about the alternator sensing wire that needs to be connected to the refer? Does anyone have this or does Airstream just not connect it for some reason?
thanks for all the help,
Jeff
11-08-2010, 09:20 AM
Wise Elder
2010 30' Classic
South of the river
What states are these? I was not aware that there were any state-wide prohibitions.
11-08-2010, 09:28 AM
Wise Elder
2010 30' Classic
South of the river
Originally Posted by lewster
Jeff,
As rptradewind noted the wattage would be approximately the same (324 watts) with either electrical source, approximately 3 amps at 120 volts or approximately 30 amps at 12 volts.
On a hot day it is not at all unusual for the element to run continuously for several hours particularly if the fridge has been opened frequently or warm food recently added as might be the case at the beginning of a trip.
Yes you can get 30 amps from the tow vehicle alternator back there but it requires tow vehicle modifications.
I would be more as concerned about fire safety with a large inverter load like that as with a gas fridge. Both are fairly safe if properly maintained, but pose risks.
11-08-2010, 09:34 AM
Wise Elder
2010 30' Classic
South of the river
O We've just picked up our new AS, after a brief stint in the Class B world. Our refer there ran on 12v, so we've kinda been used to that.
Class Bs are different and the 3 way fridges work great for them.
The fridges are half the size of the fridge in your 'stream, and require half the electricity, and that makes a big difference. There are 3 way fridges in those sizes, so no need to fuss with inverters.
In a B, all the wiring is right there so it's easy to do tricks like have a light on the dash go on if you turn of the ignition while running the fridge on 12 volts, or have it switch to gas, or whatever.
The wiring is shorter, there are fewer connectors, and it's easy to get the 15 amps or so without fancy tricks.
The coach battery is more likely to charge from the alternator, and make up any lost ground from the fridge running on 12v while parked, than is the case with a trailer.
Finally it is generally more of a nuisance to load propane on a B so conservation is more important.
11-08-2010, 08:50 PM
West Linn
Directly out of the Airstream manual...it didn't say what states.
11-08-2010, 08:53 PM
West Linn
Thanks for the clarification, all makes sense. I'm convinced to use the LP, but I just need to find out about the alternator sensing wiring from TV to AS...not sure that I'll always remember to run back and shut it off at the gas station.
11-08-2010, 10:22 PM
1966 24' Tradewind
1995 34' Excella
Lynchburg
Jeff
I am not sure that I understand your question. My understanding is that the charge line to the 7 pin connector going to the trailer is limited to 5 amps. This will charge the battery at the rate of 5 amps. I guess they figure that this will take care of the trailer lights since this is the only load.
Are you planning on turning off the gas to the frig when you stop for fuel for your TV? I don't see any reason for this.
Dan
11-08-2010, 11:10 PM
1978 28' Ambassador
Morada
The Fuse for the 'trailer battery charge' circuit on our Ford is a 30 amp fuse...as I recall, the wire is 10 ga back to the TV's 7-way plug...
There's also a 30 amp, 12 volt circuit breaker in this circuit inside our AS...
This wiring allows for timely recharging of the AS's batteries when we're on the road...
Many gas stations with room to refuel RV's I've seen have notices posted requesting that any open flame devices on the RV be shut off before operating the pumps...It's probably state law in most if not all states...
Now, in reality, when you're refueling your TV, and the trailer is some distance behind the pumps, there's probably not much danger in igniting fumes with the refer propane burner...
But why take the chance? As you drive away, you might pass close enough to some spilled fuel to cause it to ignite - remote chance, yes I know, but it's still possible...
Be safe out there...
Ray
11-08-2010, 11:11 PM
Trabuco Canyon
I use the LP when underway. But if I wanted to run the refrigerator element electrically, I'd consider installing a shore power connector at the front of the trailer. I'd install inverter in the tow vehicle and bring 120 volt power to the rear of it. Under hot weather when other loads are present on the alternator, consideration should be given to tacking another 300+ continuous watts of load on the alternator as far as life expectancy.
It is difficult to carry 300 watts at 12volt from the tow vehicle's alternator/battery all the way back to the refrigerator without excessive voltage drop. The cabling would have to be very heavy. The inverters are sensitive to low input voltage so generally are located near the 12 volt source.
