Electrical Question
I have a 25 foot 1973 Land Yacht, Trade wind. It came with a hand crank hitch elevator (?). I installed an electric one. There is a red power wire to the hitch area. It is used for the break away switch. I tapped into that red power wire to power the Hitch elevator. It worked. I moved the trailer to another part of the yard, and when I went to use the hitch elevator, no power! I opened the electrical wire compartment in the front of the trailer that has the wires for the trailer 7 point plug. I think I found the wire, by adding a wire from the tongue to the interior of the trailer and doing a continuity check. The wire is attached to some kind of solid state relay? That also has a heavy blue wire attached on the same side of the relay? and on the other side of the relay? is a red power wire that is connected to a yellow wire that goes to the 7 point plug. Can any one help me please?
