Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Batteries, Univolts, Converters & Inverters
Old 06-18-2009, 07:45 AM   #1
MaxAB's Avatar
Profile:  1977 31' Sovereign
Placitas , New Mexico
Images: 16
Electrical Distribution Center?
Anyone with suggestions for an updated DC electrical distribution system would be appreciated.
I've replaced my Univolt with an Intelicharger 9200. I've also decided to replace the two 12-volt batteries with four 6-volt deep cycle batts. I'd like to also use a 1800-watt inverter with an automatic isolation/transfer switch between the inverter and shore power AC circuit.
I plan to use 2 60-watt solar panels thru a charge/controller to the battery array.
Any suggestions or "heads-up" comments on problems to look for while making this upgrade a reality.
Thanks!
Art, Margaret, Jaki, and "Mighty" Velcro
Placitas, New Mexico
RIG: '77 Sovereign
TOWED By: '99 Suburban
HAM Call Sign: W0ABX
WBCCI #: 2197
Air #: 36503
MaxAB is offline   Reply With Quote
Old 06-18-2009, 09:08 AM   #2
FLYNCLD's Avatar
Profile:  1962 22' Flying Cloud
Bend , Oregon
Ditribution Panel
Greetings,
I recently completed an upgrade to my 62 Flying Cloud that included 2 solar panels, 4 batteries and an all new AC/DC distribution panel. I found this one from Iota to be very user friendly, and very economical!! So far it has worked perfectly. The only downside is it is plastic, but very lightweight and attractive.
IDP-30 AC/DC Distribution Panel from IOTA Engineering
Hope this helps!
FLYNCLD
Name:	New Interior 019.jpg
ID:	82519   Click image for larger version
Name:	New Interior 023.jpg
FLYNCLD is online now   Reply With Quote
Old 06-18-2009, 11:56 AM   #3
Melody Ranch's Avatar
Profile:  1956 22' Flying Cloud
1995 21' Sovereign
1947 22' Liner
Valley View , Texas
Images: 47
this may help
From another member here....Way to much for my limited system but looks like its right in line with your plans.
Old 06-18-2009, 06:42 PM   #4
MaxAB's Avatar
Images: 16
Thanks for the IOTA contact. I'll give them a call in the AM. Were you able to access all the connections needed (both AC and DC) in the front of your AS? My idea is to make all the new components fit underneath the Goucho in the front of the unit -- however, my AC circuit breaker panel is back aft in the rear head.
Do you suppose I could keep the existing AC breaker panel in place and still use the IOTA unit up front?
thanks!
Art
RIG: '77 Sovereign
WBCCI #: 2197
Air #: 36503
Old 06-18-2009, 07:59 PM   #5
FLYNCLD's Avatar
Bend , Oregon
Hi Art,
I will try and answer your questions one at a time! The AC breaker we had was a totally outdated screw in type fuse box, so it had to go. It was on the far side of the trailer from both the shore power cord and the 7 pin 12V wiring. We rewired everything to be on the same side of the trailer (pretty easy to eliminate the old fuse box) and brought both the AC/DC connections to the same point. where they really entered the trailer anyway. We were then able to bring the solar connections down to this point as well by running them through the roof and down inside the wall. This brought everything together at one point and made the it possible to install the Iota box for all systems. Everything is wired here, the inverter, converter, AC/DC and solar.
All you have to do to get rid of the AC panel in the rear is take it out and hard wire the connections back together. You will then split your circuits as needed back up front, as there is probably at least two AC circuits already existing. You just need to know where they go.
While we installed a full size queen bed instead of a gaucho, the effect is the same and you can see in the picture both the Iota unit and our solar controller in a very clean installation under the bed.
I would highly recommend that you use the Iota for everything. It will clean things up tremendously! If you need more pics, I have em'!
Name:	Electrical Update 006.jpg
tv and tt weight distribution SKEETER Tow Vehicles 7 06-18-2008 09:46 PM
Small fire at Service Center at Jackson Center hohne Our Community 32 06-07-2004 10:00 PM
weight distribution Craig Hitches 2 04-14-2003 06:57 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
