Old 11-07-2004, 02:59 PM   #1
luckydc's Avatar
Richmond , Virginia
Battery Storage
Is it safe to leave the battery hooked up to the coach over winter? I have the coach plugged into the house so the battery will get power all winter. Thought I would check the water periodically. Sound ok?
Thanks.
Paul
WBCCI #2468
2006 Ford F-150 Lariart 4X4
2004 19' Bambi Safari LS
luckydc is offline   Reply With Quote
Old 11-07-2004, 05:56 PM   #2
Retired.
. , At Large
I wouldn't reccomend leaving the trailer plugged in all winter, you could boil your batteries dry, and ruin them. On the other hand, leaving them in, and not plugged in, they could freeze, and also ruin them. Some forum members have been experimenting with a timer to only turn on the power to the trailer for an hour or so a day. That would keep the batteries charged, and minimize the chance for boiling them dry. A forum search under "boiling batteries" should find you the info.
Good luck, and have a safe winter!
Old 11-07-2004, 08:34 PM   #3
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
It all depends on what type of converter you have. Rather than use the Magnetek converter which the PO replaced the Univolt with, I use a 5 watt PulseTech Solargizer solar charger/maintainer and/or a 1 watt BatteryMinder 3 stage charger. This will be the 4th winter I've used this setup and the batteries are in great shape. I just don't worry about losing water because of the type of charger.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
vintage airstream battery wildcat455 Electrical - Systems, Generators, Batteries & Solar 4 07-02-2003 12:50 PM
Battery Exploded wayner1239 Electrical - Systems, Generators, Batteries & Solar 15 05-11-2003 08:43 AM
Univolt with Battery Minder COArgosy78 Electrical - Systems, Generators, Batteries & Solar 32 03-10-2003 07:59 PM
igniton switch and the mystery of the dead battery Curtis-79MH Airstream Motorhome Forums 3 10-25-2002 02:58 PM
Battery Storage JAG Electrical - Systems, Generators, Batteries & Solar 2 07-05-2002 02:06 PM
