Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Batteries, Univolts, Converters & Inverters
Old 10-30-2009, 02:07 PM   #1
tracker
tracker's Avatar
Profile:  1969 23' Safari
fort dick , California
battery replacement
I would like to replace the single 12 volt battery in my 69 safari with 2 6 volt agms. Does anyone know if 2 six volt batteries will fit in the same space as the 12 volt does now? Thanks.
tracker is offline   Reply With Quote
Old 10-30-2009, 03:11 PM   #2
Mexray's Avatar
Profile:  1978 29' Ambassador
Stockton , California
Airstream Registry
The short answer is NO...your existing 12 volt battery is most likely a Group-27 model, which is about 12 inches long, by about 6-1/2 inches wide...
The 6 volt (golf car) deep cycle batteries have a 'footprint' of 10 inches x 7 inches wide - EACH. so you will need a space of about 20 x 7 for end-to-end, or a space of 14 x10 for side-by-side mounting.
ALSO, the 6 volt's are about an 1-1/2 taller than the 12 volt's, so you'll need more clearance as well...
The 6 volt's are great for use in RV's, if you have the room...you'll get about 225 total Amp Hours of capacity, where as the G-27, 12 volt has about 100 Amp Hrs of capacity...
Hope that helps...Ray
Let us not be too particular;
it is better to have old secondhand Airstreams than none at all.
Mark Twain, updated (org...diamonds)
AIR # 11135
1978 - 28 ft Ambassador (Blue Halo)
2001 - Ford Excursion V-10 4x4
Old 10-30-2009, 03:50 PM   #3
vswingfield's Avatar
Profile:  1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
If it helps, you could think of your single 12 volt battery as two 6 volt batteries conveniently living together in one box. That's what it really is. Ok, it's really six 2 volt batteries living on one box compared to two boxes of three 2 volt batteries, but you get the idea. If you only have that much room, one battery that fills the space is the way to go.
Vaughan
A sixth sense (I lack the other five) tells me that I am in serious difficulties. Oscar Levant
Old 10-30-2009, 04:21 PM   #4
slpiotro's Avatar
Profile:  2007 23' Safari SE
Madison , Wisconsin
Send a message via ICQ to slpiotro
batteries replacement
I just had solar intalled and 300 AH AGM batteries installed at the same time by AM Solar in Oregon. They had a near by machine shop that was making heavy gauge aluminum covers for the batteries higher size that look great and provide a clean way to fit the big boys in the existing space. I have a 2007, 23 ft. Safari SE. (cost about 150.00 for the new covers, over doubled by amp hours)
"Honor those who serve by listening to them and caring. Parades end, caring needs to be there every day."
slpiotro is offline   Reply With Quote
battery compartment hinge replacement flash Classic Motorhomes 2 04-25-2007 06:03 PM
Battery replacement? Kistler Electrical - Systems, Generators, Batteries & Solar 15 01-17-2005 07:01 PM
Battery replacement..have SRM27 Interstate Kistler Our Community 3 11-27-2004 09:41 PM
Replacement Battery heyskipper Electrical - Systems, Generators, Batteries & Solar 28 04-04-2003 07:06 PM
deep cycle battery replacement 26Argosy.ca Electrical - Systems, Generators, Batteries & Solar 6 01-02-2003 05:19 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
