Old 02-12-2017, 01:53 PM   #1
2000 30' Excella
Toledo , Ohio
AGM Batteries replacement ?
I want to replace my wet cell batteries with AGM batteries what should I look for in a battery largest CCA or AH or both ? My current batteries are wet cell 600CCA
and 750MCA they are marine deep cycle I assume that means marine cranking amps . I looked at an AGM with 750CCA/900CA made by DEKA it'a a marine deep cycle also . Also looked at Interstate 34m 800 CCA/ 64AH they are the most expensive and better warranty . I want to replace them this spring and not sure what to look for . Any help out there ?
Thanks Les Grace
woodfox45 is offline   Reply With Quote
Old 02-12-2017, 02:52 PM   #2
Tn Traveler's Avatar
2006 25' Safari
Signal Mountain , Tennessee
On your house batteries the CCA are not very important. What you want to look for is reserve capacity and discharge rate. I think this link can explain it.
www.dcbattery.com/faq.html
Don
'06 Safari 25 LS
'18 GMC 2500HD Duramax/Allison
TN,”Greenest State in the Land of the Free”.Davy Crocket
" America is not a place;it's a road." Mark Twain
Tn Traveler is offline   Reply With Quote
Old 02-12-2017, 02:54 PM   #3
Steamy1's Avatar
2015 23' FB International
2007 19' International CCD
Steamboat Springs , Colorado
May be a good time to consider switching to two 6-volt Lifeline GPL-4CT wired in series, as many of us have done. You may have to modify the battery box as they are taller.
Steamy1 is offline   Reply With Quote
Old 02-12-2017, 02:57 PM   #4
Steamy1's Avatar
You would also need to upgrade to a 3-stage charger for AGM battery. Several links on this.
Old 02-12-2017, 03:08 PM   #5
Rich Jenkins's Avatar
Tavares , Florida
Can you elaborate on why this would be necessary for AGMs?
“Character is doing the right thing when nobody’s looking. There are too many people who think that the only thing that’s right is to get by, and the only thing that’s wrong is to get caught.” - J.C. Watts Jr.
Rich Jenkins is offline   Reply With Quote
Old 02-12-2017, 03:25 PM   #6
Steamy1's Avatar
Following are threads to shed more information on this topic to get you started :
http://www.airforums.com/forums/f449...lts-64324.html
http://www.airforums.com/forums/f449...le-109317.html
Old 02-12-2017, 03:28 PM   #7
Tavares , Florida
Ok, thanks.
Question: Does AS supply a 3 stage charger when a unit comes with AGM batteries?
Old 02-12-2017, 03:29 PM   #8
Steamy1's Avatar
Another one. See post 3.
http://www.airforums.com/forums/f37/...on-151619.html
Old 02-12-2017, 03:36 PM   #9
Steamy1's Avatar
Originally Posted by Llando88 View Post
Ok, thanks.
No; you would have to purchase it as a separate component to replace your existing charger/converter assuming you have a single stage unit. You could look at the unit and manual to verify what you have . Post it here and members will help with this.
Old 02-12-2017, 03:43 PM   #10
Tavares , Florida
I don't see post 3 as answering my question. I have AGM batteries on my '16 FC; I was trying to find out if AS installed a multi-stage charger in it.
Thanks anyway. I'll bow out.
Old 02-12-2017, 03:51 PM   #11
Steamy1's Avatar
Sorry; didn't realize you already had AGMs. If they came with your trailer you most likely have a three stage charger/converter. I would suggest looking at the manual.
Old 02-12-2017, 04:03 PM   #12
2000 30' Excella
Toledo , Ohio
I don't have the battery box on the A-frame mine has the 2 battery doors on the front of the trailer and 6 volts won't fit
Old 02-12-2017, 04:47 PM   #13
2006 25' Safari
Deka AGM batteries are manufactured by East Penn. Deka dealers will sometimes negotiate price. At any rate the price will be better. I got tired of paying the Lifeline price on my boat. I negotiated two 8d Dekas down to $485.00 ea. That's much better than he nearly $800.00 for Lifelines. Sure the Dekas will not last as long, but at about a 40% savings they are a good deal.
For optimal charging on AGMs a 3 stage chargers is best. However, the flooded battery charge voltage is close to the rate of charge of AGMS. For best charging results in the shortest charge time a 3 stage is best.
Don
'06 Safari 25 LS
Old 02-12-2017, 05:34 PM   #14
Dan and Liz's Avatar
1987 25' Sovereign
Fort Collins , Colorado
Just looked at a lot of ratings/sites/prices/warranties and decided on Trojan 27AGMs. All the sites I saw said no special charger required for them, but needed for gel cell batteries.
Dan and Liz is offline   Reply With Quote
Old 02-12-2017, 05:39 PM   #15
Naples , Florida
Actually.......not so much!!!
There are major discrepancies between the bulk/absorb requirements of liquid cells vs. AGM batteries.
For example: Many of the 'better' liquid lead acid cells like Trojan require up to 14.8VDC for a bulk/absorb charge while many AGMs like Lifeline require 14.2-14.4VDC. It may not seem so.....but a differential of 0.4-0.6VDC is HUGE!!!!
Also, 3-stage converters used as battery chargers are a severe compromise for a few reasons:
• no temperatrue compensation to vary the charge voltage as the ambient temperatures change
•*a 'one size fits all' approach to the size of the battery bank. Battery banks of larger capacity require longer absorb charge times than smaller banks
• you have to use the pre-set charge voltage levels that come programmed into the converter, which don't specifically apply to ANY battery bank
......AND......the quickest, BEST (since you mentioned the word) way to charge any type of battery bank (including lithiums) is to use a FULLY PROGRAMMABLE charger like those found on quality inverter/chargers like Magnum and Victron or Victron's dedicated battery charger systems like the Phoenix and Centaur units.
All are fully programmable for voltage settings, input amperage to the batteries, length of the absorb charge and have full temperature compensation.
lewster
Old 02-12-2017, 05:43 PM   #16
Tavares , Florida
Thanks, that's good info.
I apparently have a Parallax 8300 series inverter/converter in my '16 FC, per the Airstream OM.
From what I gather, it is a single stage converter:
"Parallax 8300 series (formerly 7300 series) are single-stage output converters providing a single voltage output of 13.8 VDC to the DC system for load and battery charging."
http://www.bestconverter.com/8300-Series_c_87.html
So far I've been happy with my AGM batteries, as well as the Solar charging system.
Old 02-12-2017, 06:31 PM   #17
Troutboy's Avatar
2017 23' Flying Cloud
Parker , Colorado
The Parallax will kill your AGMs. Get a new one that is programmable, Lewster knows his stuff. He guided me to the new system I am installing as well as many others on these forums.
Getting new AGMs and not a new charger is like changing oil and not replacing filter, or taking a shower and putting on dirty underwear! [emoji12]
Troutboy
Troutboy is offline   Reply With Quote
Old 02-13-2017, 11:14 AM   #18
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
I got 2 Optima Blue Top batteries.
Never replaced the converter/charger, just left the original Parallax (?).
Did consider the upgrade, but what I've got seems to be working.
I might upgrade in the future if I decide I need to.
1 year in so far so good.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 02-13-2017, 12:46 PM   #19
Troutboy's Avatar
Parker , Colorado
I also think it depends on the type of camping you do, if you do mainly hookup with utilities, you will not notice the issue as much. If you do more boondocking it will show more. Being plugged in hides the issue from what I have read. I'm not an expert, but have researched much. Also, I may have stayed at a holiday inn express last week[emoji6]
Troutboy
Old 02-13-2017, 12:49 PM   #20
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario , Ontario
Very useful table for re view.
MelGoddard is offline   Reply With Quote
Where to move batteries inside 23d. Upgrading to AGM batteries. Eyeballs Electrical - Systems, Generators, Batteries & Solar 36 03-08-2018 07:08 PM
Battery AGM (4) 6V GC2 vs (2) AGM 8D Torpedo Family Land Yacht/Legacy Motorhomes 3 11-15-2012 05:35 PM
Replacement of stock batteries with AGM's altamont Batteries, Univolts, Converters & Inverters 23 04-12-2009 10:24 AM
Cabelas AGM batteries wacnstac Batteries, Univolts, Converters & Inverters 26 10-13-2006 07:22 AM
Charging AGM trailer batteries from vehicle mswartz Batteries, Univolts, Converters & Inverters 5 05-15-2004 02:34 PM
