Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Generators & Solar Power
Old 01-17-2017, 06:45 PM   #1
2015 25' FB Flying Cloud
Meadow Vista , California
Solar, Inverter and Battery Questions
Considering selling my FC 25 and purchasing a 2017 Classic. I have adequate solar and batteries on my FC for most of our needs. I am curious if anyone has added a solar system, inverter and batteries that would be adequate to power the Classic and run a microwave as well. If so, what size of a system did it take?
Thanks for your input!
SS
SilverSinbad is offline   Reply With Quote
Old 01-18-2017, 10:11 AM   #2
Keeping this alive.
Old 01-18-2017, 10:36 AM   #3
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
SS,
Small microwaves are going to be 600-1000w, usually. Check the specs for what you have or will have. The Magnum or Victron inverters that are being installed are easily big enough, if you are not trying to run any other large AC loads. As for the battery bank, figure out how long you are going to run your microwave...3 minutes to heat something up or longer to cook? You can calculate the amp-hours you will take out of the battery. Almost any battery bank will be big enough for a short burst in the microwave, but remember you need to put those amp-hours back into the battery before you drag the voltage down too low.
Larry
lsbrodsky is offline   Reply With Quote
Old 01-18-2017, 12:19 PM   #4
2020 Classic 33
Box Elder , South Dakota
Multiple threads on the forums. Do a search on Classic and solar.
Gary
2020 Classic 33 Twin, 2019 Ram 3500 Longhorn, ProPride
NØVPN
ghaynes755 is offline   Reply With Quote
Old 01-18-2017, 02:23 PM   #5
Thanks for suggesting the search option ghaynes755, unfortunately i haven't a post that covers inverters and microwaves.
Old 01-18-2017, 02:56 PM   #6
2016 28' International
2015 28' International
2013 28' International
Las Vegas , Nevada
I have the twin 160W panels with a 1000W inverter, it will run the microwave, but does not heat well. I suggest at least a 2000W inverter to run the microwave satisfactory.
vintagemotor is offline   Reply With Quote
Old 01-19-2017, 02:19 PM   #7
Tbeck11931's Avatar
1990 34' Limited
2013 27' FB International
Conroe , Texas
Silversinbad
Check out: www.amsolar.com
Thomas
Tbeck11931 is offline   Reply With Quote
Old 01-19-2017, 02:55 PM   #8
2007 31' Classic
Gulf Breeze , Florida
My setup is 500 watts pv on the roof. Four Crown AGM six volt batteries, magnum 3000 watt hybrid inverter, blue sky charge controller. I can run my 15000 btu AC...for a short time, microwave, induction cooker, hair dryer...no problem, just not all at once.
2007 International CCD 28
www.emeraldcoastcamper.com
trumpetguy is offline   Reply With Quote
Old 01-22-2017, 12:32 AM   #9
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
Originally Posted by lsbrodsky View Post
SS,
Larry
Most compact microwaves are about 700 watts. This is microwave output power. The input power is considerably higher. My 700 watt microwave has a listed power consumption of 1,050 watts. However when I operated it, the measured power consumption was 1185 watts, 70 percent higher than the rated output and 175 watts more than the specified power consumption. I purchased a 600 watt microwave hoping that I could operate it with my 1,000 watt inverter. The specified power consumption was 850 watts, but the measured power consumption was 1,020 watts, again 70 percent higher than the rated 600 watt output. So, I can not operate it with my 1,000 watt inverter. I tried, but it tripped offline. I have learned that if I want to operate a compact microwave, I will need to go to a 1,500 watt inverter. This should be adequate for any compact microwave with an output power no greater than about 850 watts.
Dan
Solar, Inverter and Battery upgrades kaylorsan Sprinter and B-van Forum 26 05-11-2017 06:11 PM
Battery Monitor versus Inverter Install Questions Searun Batteries, Univolts, Converters & Inverters 4 05-24-2016 01:34 PM
Electrical Fire after solar and inverter install jasperkins Electrical - Systems, Generators, Batteries & Solar 15 05-19-2014 03:55 PM
Solar/Battery/Inverter plan cmreumund Batteries, Univolts, Converters & Inverters 10 02-06-2009 08:54 PM
Solar Panel and Inverter Issues on 19ft Bambi campadk Generators & Solar Power 10 10-28-2006 09:59 AM
