Old 11-26-2015, 10:08 AM   #1
Argosy 7728's Avatar
1977 Argosy 28
Irrigon , Oregon
LP Generator
Has anyone used this LP generator, thoughts?
Amazon.com : Generac 6001 LP5500 5, 500 Watt 389cc OHV Portable Liquid Propane Powered Generator with Tank Holder (CARB Compliant) : Patio, Lawn & Garden
Rod
AIR# 60278
Argosy 7728 is offline   Reply With Quote
Old 11-26-2015, 10:12 AM   #2
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
I am not familiar with this specific model but it's going to be a noisy one. Do yourself and your neighbors a favor and stick with Honda or Yamaha inverter style generators.
Bob Martel
WBCCI# 5766
Old 11-26-2015, 10:18 AM   #3
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
I haven't used that particular model, but I do have some experience with Generac generators through my former work. They're reliable, but they're LOUD compared to other generators of comparable output. Generac's primary market is the construction industry, where workers are likely to be wearing OSHA-compliant hearing protection anyway and therefore don't particularly care how many decibels the generator puts out.
Old 11-26-2015, 10:28 AM   #4
1977 Argosy 28
Irrigon , Oregon
Yea I know it's louder 65db vs Honda 2000 - 59db. I am looking at it as a home backup and occasional boondocking.
Rod
AIR# 60278
Old 11-26-2015, 10:29 AM   #5
1977 Argosy 28
Irrigon , Oregon
Thanks Protagonist
I was mainly intrigued because of the mounted LP tank.
Rod
AIR# 60278
Old 11-26-2015, 11:16 AM   #6
Chelsea , Michigan
Images: 12
Originally Posted by Argosy 7728 View Post
Thanks Protagonist
We have a Yamaha ei2000 that has been modified to run on LP, Nat Gas or gasoline and we hook it up to the auxiliary LP port on the Airstream at the front of the trailer. We never run out of propane!
Bob Martel
WBCCI# 5766
Old 11-26-2015, 11:26 AM   #7
that's a difference of 6dB, which means the Generac is FOUR times as loud.
Old 11-26-2015, 01:06 PM   #8
Chelsea , Michigan
Images: 12
And I suspect that the 65dB claim is a stretch. Contractor generators are a real scourge in campgrounds and should be against the rules.
Bob Martel
WBCCI# 5766
Old 11-26-2015, 02:18 PM   #9
2008 27' Safari FB SE
Miami , Florida
65dB will draw a mob of villagers with torches and pitchforks in most western parks.
Mike
Sorta new (usually dirty) Nissan Titan XD (hardly paid for)
Middle-aged Safari SE
Young, lovely bride
Dismissive cat
Old 11-26-2015, 06:12 PM   #10
1977 Argosy 28
Irrigon , Oregon
AH HA. I was wondering how much louder that would be. So if 2 Honda 2000 hooked together at 59db, how much doe's the noise level rise or doe's it?
Rod
AIR# 60278
Old 11-26-2015, 06:31 PM   #11
DKB_SATX's Avatar
Alamo Heights , Texas
I don't know the measurement, but it's not 2x as loud as one 2k Honda running by itself. An interesting difference is that the full-sized 3k Honda seems distinctly QUIETER than one 2k, much less 2. My 3k Yamaha also seems quieter than the 2k.
— David
Old 11-26-2015, 06:34 PM   #12
Chelsea , Michigan
Images: 12
Yes, running two H2000's together is noisier than running one (based on personal observations.) I don't know the actual impact on dB.
Understand that the manufacturers usually quote their dB's based on no or very light load, if you put a load on your generator (duh!) the noise will be higher than the rating. For this reason, the difference between the inverter and contractor type of generator is actually greater than the ratings would suggest when they are run under load.
If you use one of the contractor type of generators, be assured that your neighbors are wishing all kind of pestilence on you, your ancestors and your descendants.
Bob Martel
WBCCI# 5766
Old 11-26-2015, 06:37 PM   #13
Chelsea , Michigan
Images: 12
I had the unusual opportunity to hear a Honda 3000 today followed by a Honda 2000 a few sites down the way (for my first real life "side by side" comparison) and the 3000 was definitely noisier than the single 2000. But nowhere near as obnoxious as a contractor generator.
Bob Martel
WBCCI# 5766
Old 11-26-2015, 06:43 PM   #14
DKB_SATX's Avatar
To add a bit of detail to that, Yamaha (and I believe Honda) rate their generators at 1/4 load for both noise level and run time on a tank. For anything above a 1k unit, charging up your batteries and running lights/fans/radio is 1/4 load or less, but if you leave the fridge on auto or hit the microwave you'll hear it spool up to carry the load.
— David
Old 11-26-2015, 06:43 PM   #15
Mantua , Ohio
There are two models of Honda 3000 gens. One is much quieter than a 2000 , the other louder.
Old 11-26-2015, 06:52 PM   #16
Twice as loud, which means 3dB higher.
Old 11-26-2015, 07:42 PM   #17
1977 Argosy 28
Irrigon , Oregon
Yes the Honda is 59 at full load and 53 at 1/4 load
Rod
AIR# 60278
Old 11-26-2015, 07:46 PM   #18
1977 Argosy 28
Irrigon , Oregon
Nowhere in this statement did I suggest using it in a campgound
Rod
AIR# 60278
Old 11-26-2015, 07:50 PM   #19
1977 Argosy 28
Irrigon , Oregon
Thanks to everyone that gave me constructive input.
Rod
AIR# 60278
Old 11-26-2015, 11:42 PM   #20
DKB_SATX's Avatar
As others noted, there are 2 Honda 3000s. The lighter, more expensive "Handi" is louder than the full-sized EU3000iS, which is why I said the full-sized one is quieter than a 2k.
— David
Parallel non inverter generator with inverter generator? mtbguy Generators & Solar Power 3 07-15-2015 01:48 PM
Solar or generator or and generator? badkat Full-Timing 15 11-17-2014 09:59 PM
Generator Problems thenewkid64 General Motorhome Topics 27 05-07-2003 09:36 PM
Generator Paul Daugherty Airstream Motorhome Forums 19 08-09-2002 08:47 AM
1998-1999-2000 Excella Generator fphil Airstream Motorhome Forums 0 07-01-2002 09:34 PM
