01-09-2014, 06:01 AM
#21
2011 30' Flying Cloud
Arvada
At one time I owned a 3000i Handi, but sold it for a couple of reasons - weight and limited storage capability while traveling. I had purchased a six gallon external fuel tank from Honda Portable Generator, EZ Flow Extended Fuel System, Dallas, Fort Worth. As others have mentioned, it worked with the 3000i as long as the external tank is set more or less on the same plane as the genny.
As an aside, I ended up with two 2000i's which is the best solution for me. Good luck and congrats on your purchase.
08-17-2014, 06:20 PM
#22
2013 28' Flying Cloud
Central
, Canada
Just checking in to see if this is still the best option for extending the fuel supply for a EU3000I (Handi). The 80 lL unit with wheels and extendable handle.
Doug
Trying to use my camera to create memories - not photographs!
08-18-2014, 07:20 AM
#23
Alpharetta
, Georgia
Originally Posted by MrAgent007
The Honda 3000 handi apparently does not have the built in diaphram fuel pump in the carb and therefore no vacuum is created to draw in fuel from a tank located lower than the generator.
The Honda EU3000i Handi is a gravity-feed fuel system, and does NOT have a fuel pump.
A couple of other Honda models (EU2000i, EU1000i) do indeed have diaphragm/vacuum type fuel pump. I'm not aware of any aftermarket external tank systems that do work on generators without a fuel pump.
Robert@Honda
Social Media Consigliere
Caveat: I work for Honda, but the preceding is my opinion alone.
08-18-2014, 07:22 AM
#24
Oswego
I have read that the extended run tanks work without a fuel pump if you elevate the external tank above the level of the internal fuel tank.
-Rich-
08-18-2014, 07:40 AM
#25
Sneedville
, Tennessee
There are several videos on youtube about making an external tank work with a generator with no fuel pump.
08-18-2014, 08:21 AM
#26
Central
, Canada
Looking on the net, it seems like a simple enough system as long as you set it up and use gravity to feed the tank. Gosh I might even have a spare outboard motor tank kicking around. The trick will be to find a gas tank top that will fit the generator. anyone got any ideas?
TKS
Doug
08-18-2014, 08:41 AM
#27
Oswego
Although my Hondas have fuel pumps, I made my extended run tanks by using an outboard tank I had, a new outboard fuel line with primer bulb, a line tee, additional fuel line, a fuel filter, outboard connectors and the aluminum caps sold for this purpose. Less than half the cost of the commercial system, as I recall.
-Rich-
08-18-2014, 08:49 AM
#28
Central
, Canada
Hi Rich:
you don't happen to has a photo of the rig you built do you? also would you remember where you got the alum gas cap?
TKS
Doug
08-18-2014, 11:04 AM
#29
2020 Classic 33
Box Elder
, South Dakota
Search Honda Extended Run on eBay. Lots of them out there.
Gary
2020 Classic 33 Twin, 2019 Ram 3500 Longhorn, ProPride
NØVPN
08-18-2014, 11:10 AM
#30
Oswego
Originally Posted by Arcticfox
Hi Rich:
TKS
Doug
Hi Doug
Here's some caps....shop for best price....I don't remember paying this much!
Honda EU2000I Generator Extended Run Fuel Cap | eBay
Here's a pic of my setup:
-Rich-
