Old 05-26-2009, 09:24 PM   #1
nilesrob's Avatar
Hampton , New Hampshire
Images: 12
Running lights
Really quick question - what pins do I jumper to get the running lights to light while plugged into power? Thanks.
Brad (The Slowsky's)
2019 Airstream Classic 30RBT, 2021 Ford F350 King Ranch 4X4 w/6.7L Diesel, Hensley, ACI #1313
travelwiththeslowskys.com
nilesrob is offline   Reply With Quote
Old 05-26-2009, 09:30 PM   #2
Retired.
. , At Large
The top pin and the one next to it.
Old 05-26-2009, 09:40 PM   #3
nilesrob's Avatar
Images: 12
Awesome, thank you!
Old 05-27-2009, 07:05 AM   #4
Silverhobby's Avatar
Greeeneville , Tennessee
Brad, If you really want to be "flashy", install a 2 prong HD flasher (with prongs at a 90 degree angle) into the trailer cord. This will use the battery's power and flash all the lights at the same time.
//------AIR # 7303------\\
WBCCI 17109
visit my restoration blog at:
Old 05-27-2009, 08:10 AM   #5
richinny's Avatar
2011 34' Classic
make sure you're ready for company first!
Ricky
Old 05-27-2009, 07:29 PM   #6
nilesrob's Avatar
Images: 12
OK, I guess I need a little more help. What is the "top" and to which side is the one next to it?
Old 05-27-2009, 07:44 PM   #7
Retired.
. , At Large
The top pin is the one on top of the plug when it is connected in normal fashion to the tow vehicle. The squarish knob-ish thing on the plug should be at the top.
Old 05-27-2009, 07:45 PM   #8
Mexray's Avatar
1978 28' Ambassador
Morada , California
Here's about the best diagram around, shows everything you'll need to know...
http://www.countrytrailer.com/Manage...S/7wayplug.pdf
you can plug a 2-prong flasher unit between the + and Tail lights to get them to blink using the trailer's battery...if you plug it into the + and RH stop lights, they will blink...
I've made a control box that I plug the 7-way cord into that allows me to 'flash' the tail/marker lights, the stop light, and the back up lights...I can also switch it to 'full on' to turn either one of the circuits on fully, for any one of the three...cooool.....
Name:	DSCN1086 [Desktop Resolution].JPG
Ray & Pat; Morada, CA
Old 05-27-2009, 07:48 PM   #9
Retired.
. , At Large
You just don't want to do that in downtown LA, you'll get arrested for indecent exposure...
"flashing"... crawling back under my rock now...
Old 05-27-2009, 08:12 PM   #10
Mexray's Avatar
1978 28' Ambassador
Morada , California
I guess our old AS is a Naturalist at heart, flashing, every chance it gets...
Old 05-27-2009, 08:20 PM   #11
Graham , North Carolina
mexray, I'd sure like to have a diagram of that little box
jerrypeterma is offline   Reply With Quote
Old 05-27-2009, 09:05 PM   #12
Mexray's Avatar
1978 28' Ambassador
Morada , California
Here's a first draft...I've got to add a diode in one of the green LED indicator lamps, to keep them both from coming on...
Hope you can read it...it's rather straight forward, I use the + battery pin to power the flasher, LED indicators, and all the trailer lights (all of mine are LED units, except the backup lamps, and they will be converted shortly)...
With the Master Switch (on the left), UP is FLASH, CENTER is OFF, and DOWN is constant ON...you then select which circuit; TAIL, STOP, or BACKUP you wish to power up...or all at the same time - looks really COOL with all the lights flashing in the night....
With this FLASHER BOX, one can flash the trailer lights if on the roadside, unhooked, while running in the TV for parts, etc...or I can irritate my Rally neighbors...or with a remote control wired into the BOX, I could find our AS in a crowded WalMart parking lot...
Name:	Flasher Diag [Desktop Resolution].JPG
Old 05-27-2009, 10:48 PM   #13
Mexray's Avatar
1978 28' Ambassador
Morada , California
Took some Pic's of our BLUE HALO tonight...enjoy!
Name:	Stop Lts [Desktop Resolution].JPG
ID:	81015   Click image for larger version
Name:	BU Lts [Desktop Resolution].JPG
Name:	BH Lic Plt [Desktop Resolution].JPG
ID:	81017   Click image for larger version
Name:	Blu Halo [Desktop Resolution].JPG
Old 05-27-2009, 11:30 PM   #14
msieber109's Avatar
1966 24' Tradewind
1975 29' Ambassador
Greenfield , Massachusetts
Mexray...that looks pretty sharp.
Is the Blue Halo rope lights permanently attached or do you have to install them everytime when you setup?
msieber109 is offline   Reply With Quote
Old 05-28-2009, 01:28 AM   #15
Mexray's Avatar
1978 28' Ambassador
Morada , California
The rope lights are permanent...I mounted them in the lower alum channel that would normally carry the wide blue vinyl strip...
I removed every other rivet that holds the alum channel to the body, and mounted a clear plastic 'u' channel that just fit perfect, and installed new rivets...I got the plastic channel from the rope light supplier, the rope light just 'snaps' into the channel and you're done!
These rope lights are not LED's (a bit pricy!)...they are the regular kind...I made two runs, one down each side, ending at the rear...I power them from the tongue jack circuit up front...
As you can see, I had to go up over the wheel wells, and under the water heater in order to use one continious 'rope'... on the curb side I also had to go under the door...but I think it still came out kinda 'cool'...
I got the rope lights and accessories from a store in TX, I believe...called 1000bulbs.com, as I remember...they have all you'd need, in many colors, in different sizes and voltages...mine are 12 volt type...
Old 10-09-2010, 06:00 PM   #16
Canada , Manitoba
I love the way the rope lights look or your AS .
Can you post a picture of the power source connection? Do the lights work when you are parked and not hooked up to your towing rig or when you are pulling and connected to the power source?
SnoSheriff is offline   Reply With Quote
Old 10-09-2010, 06:36 PM   #17
the ponz's Avatar
Detroit , Michigan
Do you think there should be a fuse located anywhere in the circuit ?
86' 31' Sovereign
the ponz is offline   Reply With Quote
Running Lights cameront120 Lights - Interior & Exterior 4 03-23-2006 09:23 PM
Running lights Devoman Our Community 16 03-21-2006 08:45 AM
Running Lights/Backup Lights 85 Sovereign GRAYMAN Lights - Interior & Exterior 7 08-10-2004 08:54 AM
Running Lights Joe Z Lights - Interior & Exterior 7 12-11-2003 08:48 PM
running lights mazda997 Electrical - Systems, Generators, Batteries & Solar 0 08-27-2003 08:55 PM
