05-07-2012, 09:32 PM
1967 24' Tradewind
Blairstown
, New Jersey
Frosted 1176 Bulb
Does anyone have a source for a frosted 1176 bulb for a '68 vanity mirror?
Wayne
05-10-2012, 07:03 AM
Newcastle
, Oklahoma
I have seen this, don't know if it works.
Amour Etch Cream, found on eBay
05-10-2012, 08:13 AM
Figment of My Imagination
2012 Interstate Coach
From All Over
, More Than Anywhere Else
This site has LED replacements for the 1176 automotive bulb, if you would like to try that route: LED Car Bulb Replacement Reference - Super Bright LEDs
05-10-2012, 11:19 PM
1967 24' Tradewind
Blairstown
, New Jersey
Thanks for the replies. I've thought of etching some clear 1176 to try to mimic the old frosted units. If etching one doesn't look good, I'll etch four.
The table lists LED replacements for bulbs with a single filament and a double filament as if they were the same. For example, an 1156 is a single filament bulb while an 1176 is a double filament. The '68 vanity mirror switch has a position with the low wattage filaments on, then the high wattage, then both. Will the LED respond properly?
Wayne
05-11-2012, 04:56 AM
From All Over
Can't promise they will, but they should. I have LED lights (not 1156, though) that have bright/dim settings.
05-11-2012, 07:19 AM
1998 31' Excella 1000
1979 23' Safari
Mooresville
, Indiana
I'm very sure that I saw these bulbs at Airstream last week. They had a big selection of frosted bulbs and LEDs in there store. Might want to give them a call.
05-11-2012, 09:20 AM
1983 34' Excella
1967 24' Tradewind
Little Rock
, Arkansas
Vaughan
05-11-2012, 04:05 PM
Hendersonville, NC
, North Carolina
Our '68 overlander vanity lamps are frosted GE1141IF (inside frosted). single element. 1st position the top two come on - 2nd position the bottom two and the third - all come on- then back to off. The bedroom reading lamps are (on mine at least) clear 1176 (two element).
#1141IF INSIDE FROSTED MINIATURE BULB BA15S BASE, S8 SC BAY 12V 21CP FROSTED, 1141IF,#1141IF, #1141IF MINIATURE LAMP, #1141IF BULB, #1141IF LAMP, #1141IF INDICATOR, EIKO#40115,BOMBILLA,BIRNE,AMPOULE,BULBO
05-12-2012, 09:52 AM
Denton
, North Carolina
1176 double contact
Wayne
The 1176 bulb has the double contact on the bottom and to find a the double contacts with the big round bulb can be a challenge. We tailor made an application for a customer who wanted an LED because he Boondocks a lot. His unit used an 1156 socket but the 1142/1176 bulb is available.
BWP1156BWF is the part number. The 1176 would be the same with a different socket. Both are in stock.
Dan Brown Denton NC
05-12-2012, 11:32 PM
1967 24' Tradewind
Blairstown
, New Jersey
>>Our '68 overlander vanity lamps are frosted GE1141IF (inside frosted). single element. 1st position the top two come on - 2nd position the bottom two and the third - all come on- then back to off. The bedroom reading lamps are (on mine at least) clear 1176 (two element).<<
Does your vanity look like the attached? I expected the lamps to come on like yours do, but I had problems checking its operation due to a failing switch. When I put in a new switch, along with refurbishing the whole unit, the lamps worked oddly. The problem was that there was on 1156 lamp and three 1176 lamp. Upon further inspection, I noted that all four sockets had two white wires, and looking inside the socket there were two terminals. Check your vanity and let me know if there are two terminals in your sockets. I'm interested to know if your vanity is exactly the same.
Wayne
05-13-2012, 08:21 AM
Hendersonville, NC
, North Carolina
vanity bulbs
Yes, ours looks the same, however the sockets only have one contact. I had to replace the switch also. The switch pattern is awkward I feel. Only one terminal in each socket - dead center. I thought a brake/tail lamp would work in the reading lights in the bed room, however the bayonet tips are different heights on a car bulb so you would get it installed correctly. Then I discovered it was a two filament 1176 bulb. Vintage trailer supply has the frosted and clear 1141's, plus they have the 1176 also. I think the LED would be the way to go as these 1141's give off a lot of heat and when all are on the fixture is pulling ~6amps.
Good luck,
Pat
05-16-2012, 07:30 AM
1967 24' Tradewind
Blairstown
, New Jersey
That's very interesting that your sockets are one terminal. Would Airstream have produced two different kinds, and made it an option? It would be too expensive I would think to produce two since the existence of these vanities is pretty limited. Perhaps the two terminal socket was a later production and they stopped producing one terminal types.
Wayne
05-16-2012, 03:19 PM
Hendersonville, NC
, North Carolina
I bet they did as the pattern on ours is awkward - top -bottom - both. With two filament bulbs you would get three brightness levels with more even light.
Here's another source for the 1176IF
https://www.interlight.biz/light-bulb/1176IF
good luck,
Pat
05-17-2012, 10:40 AM
1967 24' Tradewind
Blairstown
, New Jersey
>> the 1142/1176 bulb is available<<
Now I understand. I was looking for 1176 in the links I've been sent for LED when I should have been looking for the two terminal base as an 1142.
Wayne
05-17-2012, 10:44 AM
1967 24' Tradewind
Blairstown
, New Jersey
Pat,
How did you find these? My internet searching turned up nothing. You're good! Now that I understand that the LED have the proper base, I need to decide if I want the traditional style or LED. I'll probably stay with the traditional since I don't expect to boondock very much.
Wayne
09-18-2013, 07:12 PM
1967 24' Tradewind
Blairstown
, New Jersey
The Interlight link turned up empty, as the company does not have the lamps and has not for a while. This doesn't seem unusual for some internet companies not to update their sites regularly, at least in my experience.
I have ended up frosting clear 1176 lamps with the Armour Etch that Barkingdogg recommened and have found it works quite well. The cream needs to be left on for much longer than the bottle suggests, but leaving it on for several minutes doesn't seem to affect the result badly. I did tape the metal part of the lamp to protect it from the acid, and then washed the cream off and dried the glass. The only real difference I can tell for the inside-frosted originals is the rough texture. The look of both lamps lit is almost indistinguishable.
Wayne
