Old 06-14-2010, 05:27 PM   #1
lompoc , California
Bathroom lights do not work
I can't find location of fuse box on our 1974 31' Sovereign.
jakenan is offline   Reply With Quote
Old 06-14-2010, 05:46 PM   #2
Remember, Safety Third
Jim & Susan's Avatar
Catfish Corners , Georgia
Welcome to the forums Jake. In our '73, the fuse panel was attached to the front of the Univolt (big blue power rectifier) and the Univolt was mounted under the shower. Ours is a rear bath model, so yours may be in a different place. Good luck.
Solve for X, Or is it Y?
www.nesa.org
Air No. 6427
Old 06-14-2010, 06:50 PM   #3
lompoc , California
thanks i will check tomorrow.
Old 06-14-2010, 08:53 PM   #4
Ottawa , ON
Jim's right. Get on your knees in front of the curbside closet just ahead of the bath, and stick your head inside. It's at the bottom on the right side. Pull the blue door open. 8 fuses, on the right side, the ones for the purple and yellow wires may well be blown.
For some reason the bathroom lights are a common problem with that year and model (rear bath). Mine heat up the circuit that they are one (purple, IIRC), and are a constant bother.
Next project for me is to install the new voltage converter I bought late last fall, and see if that makes the bathroom (and sleeping area) lights work. If it isn't I am going to try running a new wire, since I fear that there is a short inside the wall somewhere.
Keep us advised as to what happens for you?
ps: welcome! Howzabout some photos of your rig?
Running Lights don't work, Other exterior lights work jrvly1976 Lights - Interior & Exterior 15 01-27-2015 09:27 PM
how does Hehr bathroom vent operator work? steverad Roof Vents, Skylights & Fans 1 04-20-2010 08:00 PM
Bathroom vanity and Bathroom vent lights... sovereignrwe Electrical - Systems, Generators, Batteries & Solar 10 01-05-2010 06:30 AM
Safari 27 Bathroom lights won't work Brow324 Electrical - Systems, Generators, Batteries & Solar 7 11-20-2009 10:34 AM
