09-12-2007, 01:41 PM
1965 26' Overlander
2009 27' FB International
Winnipeg
, Manitoba
1965 Interior Overhead Bulbs
What is the correct bulb # that goes in the overhead rectangular light fixtures? Right now there are a variety of different bulb #'s in there.
Thanks.
09-12-2007, 01:59 PM
Colville
Thanks.
Here's a thread that gives the bulb numbers for a '64 - They're probably still the same in '65.
http://www.airforums.com/forums/f37/...4-a-19931.html
AIR 12256
Currently Looking
2001 Dodge Ram 1500
2001 Honda XR650R
Currently Looking...for an Avion Truck Camper (or a Classic Argosy MoHo)
"In regione caecorum rex est luscus." GP
09-12-2007, 03:43 PM
Corona
Thanks.
The correct bulb is 1141 that has a clear bulb.
Or, if you prefer more diffused light, you can use 1141 F (frosted.
09-12-2007, 05:21 PM
, At Large
And if you are planning on doing LOTS of boondocking, you can look into the #1156W LED bulb. Direct fit, very low amp draw, very high initial cost, but last virtually forever.
09-12-2007, 05:31 PM
1978 31' Excella 500
Venice
Caution!
The thing to watch for is mistakenly using an automotive turn or tail light bulb(#1156). They look the same, but draw more current, and more importantly for the fixture, get HOTTER. I think Andy pointed this out before, but keep it in mind.
09-12-2007, 06:37 PM
, At Large
Exactly. LED's don't get really hot, so there is little danger of heat damage to fixtures with them, but don't substitute a regular 1156 in place of an 1141. End result will be melted lights.
09-12-2007, 10:13 PM
1965 26' Overlander
Winnipeg
, Manitoba
Thanks for all the replies everyone. I'll go look for a bunch of #1141 bulbs tomorrow for my overhead fixtures. Now, how about the reading lights? I have three sets in my trailer that look like these ones. What is the proper bulb # for them? Thanks again!
09-12-2007, 11:01 PM
Colville
Same bulb - #1141
AIR 12256
Currently Looking
2001 Dodge Ram 1500
2001 Honda XR650R
09-13-2007, 05:28 AM
Corona
That light is the original "bullet" light used by Airstream.
The correct bulb looks like a funnel.
It's number is 1383.
09-13-2007, 05:30 AM
, At Large
The 1141 fits nearly every incandescent light fixture in our trailers. An interesting exception is when you move outside, the scare light takes, IIRC, a #1037, double filament bulb that looks like a standard tail/turn signal bulb. It is not, and the 1157 will melt the lens if used.
09-13-2007, 06:20 AM
1971 27' Overlander
Central
Terry,
The manual for 71 at least shows a bulb #90 for the outside lights..?
Darn if it doesn't look like another project - going around and checking that the bulbs are all correct.
