Replacing my 2088-422-144 / 2.8 gpm water pump with a 2088-544-144 / 3.5 gmp. Will I have a problem with this being too much pressure for the line?
It'll be about the same shutoff pressure, which is when it has the highest pressure. But pump will be capable of producing more flow which will keep the operating pressure higher when there is flow, still lower than shutoff pressure. You will see more flow and better pressure at the faucets.
