Originally Posted by Mrad7777
I am working on a 1971 excella . the sink and wall moulding have some
cracks and small holes. What material should be used to patch this up ?
Cut some excess plastic material where it will not show.
Dissolve it in some plastic solvent. Make it a thick liquid.
"V" groove the cracks.
Apply the liquid plastic into those grooves.
Let it set up for a couple of days.
Then, add more plastic to the grooves.
Repeat as many times as necessary to allow an excess buildup.
Make super sure that the plastic has hardened.
Wet sand the excess down, until the excess is gone.
Lastly, polish the area with a buffer as need be, starting with a "compound" and then going to a wax.
