Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Sinks, Showers & Toilets
Old 09-13-2007, 12:02 PM   #1
Sovereign86's Avatar
1986 31' Sovereign
Rockmart , Georgia
Smile Replacing kitchen faucet
The faucet in my 86 Sovereign has about had it. It is leaking and I think I am just going to replace it. After looking under the sink I am wondering if I can replace with a modern pullout faucet, which is what I would like to do. First of all, there appears to be a maze of tubing/pipes under the sink. There is the supply line going into each faucet handle, plus another line coming out from under each handle leading to the faucet. Finally, the tubing from the faucet to the spray.
Most faucets in the past few years I have replaced in my house have only had the two supply line connections, plus an optional line leading to a spray. I am not familiar with the additional line leading from each handle to the faucet itself. Is that unique to, and necessary for, an rv/camper? Can I remove all those existing lines and replace with a modern faucet, and just simply hook up the two supply lines?
For now I am just going to replace the o-rings and see if that helps the leak.
Thanks for any responses!
Sovereign86 is offline   Reply With Quote
Old 09-13-2007, 12:10 PM   #2
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
Nope, nothing special - go to Lowes or Home Depot and get the same Moen I have in my CCD. Single handle - pull out sprayer. It will hook right up. Use flexible lines they have there and save yourself lots of re-pipeing of the supply lines if you have hard copper lines.
I see my model on the shelf each time I go to HD.
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 09-13-2007, 12:13 PM   #3
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
You sure can, we have one in our '74 Overlander, flex lines as well.
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Old 09-13-2007, 12:25 PM   #4
1986 31' Sovereign
Rockmart , Georgia
Thanks, Clancy and Balrgn...I'm going to replace this weekend!
Old 09-13-2007, 03:37 PM   #5
Liberator
klattu's Avatar
1972 Argosy 24
1989 34.5' Airstream 345
Heart of Dixie , Alabama
Images: 834
Silver Streams
Just make sure it looks 'Airstreamy'
klattu is offline   Reply With Quote
Old 09-13-2007, 06:57 PM   #6
1986 31' Sovereign
Rockmart , Georgia
Will do!
Kitchen Faucet Repair hhessig Sinks, Showers & Toilets 2 05-23-2006 03:16 PM
Replacing kitchen faucet Campn4fun Fresh Water Systems 2 08-19-2004 02:40 PM
Installed new kitchen faucet! Stefrobrts Fresh Water Systems 18 07-16-2004 11:33 PM
kitchen faucet leaking Stefrobrts Fresh Water Systems 10 03-16-2004 09:44 AM
Kitchen Faucet Repair niftypkg Sinks, Showers & Toilets 13 09-27-2002 05:02 PM
