Old 10-29-2010, 01:24 PM   #1
Mantua , Ohio
where the waterpump is
Where in the heck is the water pump in a 2005 Safari fb twins. 25 footer. Has to be under a panel somewhere. zz
Old 10-29-2010, 02:12 PM   #2
cclarkego's Avatar
1966 24' Tradewind
Oak View , California
Images: 8
Turn it on and then you'll hear it...
cclarkego is offline   Reply With Quote
Old 10-29-2010, 02:37 PM   #3
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
It is located behind the the panel under the wardrobe. It's the panel with the furnace duct in it. It is hinged on the left. Open the wardrobe door and pry the door open on the right. The water pump is behind the furnace duct mounted to the floor.
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
Old 10-29-2010, 03:43 PM   #4
Mantua , Ohio
Thanks Moosetags, doesn't work so can't here it. zz
'71 overlander poor water pressure on waterpump. neokans Plumbing - Systems & Fixtures 2 02-28-2010 01:11 PM
Isuzu 6BD1A Waterpump ??? jking Mechanics Corner - Engines, Transmission & More... 11 07-12-2009 10:49 PM
91 350le waterpump not working jerry220ver Water Heaters, Filters & Pumps 4 11-22-2006 04:41 PM
MORE POWER!! Newer bigger waterpump? Steve Heywood Water Heaters, Filters & Pumps 10 04-24-2005 10:27 PM
