Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Water Heaters, Filters & Pumps
User Name
Password
Portal Register FAQ Members List Rally Calendar Chat Room Mark Forums Read
Welcome to the AIRForums.com the community where Airstream enthusiasts meet online. Our members have contributed over 30,000 pages of information about Airstream Trailers & Motorhomes.
You are currently viewing our site as a guest which allows you to read most all of our content. By joining our community (For FREE) you will have access to participate in the discussions, post new topics, connect and communicate with other members, respond to polls, upload your own photos, post classified ads and access many other special features.
Registration is fast, simple and absolutely FREE so please join our community today!
Click Here to Register!
- Monthly Newsletter
Old 09-04-2002, 01:33 PM
smily
"Still Working"
smily's Avatar
Profile:  North Charleston, South Carolina
Water Hammer
Our 27 Overlander has a shureflo pump with plastic water lines connected to it.
The pump works very good but man you can hear the water hammer, (loud noise to those who dont know what water hammer is), It sounds like a loud shudder through out the AS.
I have looked around for info on this but I have not seen any good solutions.
Is there a way to eliminate this noise?
Insulation will do very little to dampen this noise being that you can hear it through out the trailer.
The pump is mounted on shock absorbers and there seems to be plastic pipes between the pump and th original hard lines, (I think they are copper not sure).
I have heard of methods used in homes that provide for "vapor lock or air lock".
Does anyone have any ideas or suggestions?
Smily
Get rid of these ads... register today, it's FREE
Old 09-04-2002, 03:03 PM
thenewkid64
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay, Florida
Smily,
Check out this thread
http://www.airforums.com/forum...water+ha mmer
Brett G
WBCCI #5501 AIR # 49
"Stop worrying about the potholes in the road and celebrate the journey." -- Fitzhugh Mullan
Wise men talk because they have someting to say; fools, because they have to say something. -- Plato
In politics, absurdity is not a handicap— Napoleon
Old 09-05-2002, 06:24 AM
smily
"Still Working"
smily's Avatar
Where to mount accumulator
Okay,
I have been to Water Hammer thread.
I did not see where any one recommended the location to install Accumulator.
Does it matter.? I am guessing somewhere near the pump?
or should it be at the farthest point from the pump?
I am going to change my water lines to the pump from stiff plastic, (PEX), to soft flexible lines.
Unlike some of the post' at the repective thread, my noise actually starts out loud and dwindles as the pressure builds up.
I read at the thread that typically the noise starts out low and builds up relative with the pressure.
My noise actually stops whaen the pump stops.
I find it hard to believe that the impellar makes this much noise.
The noise is very loud. I am concerned that the noise will actually scare our infant.
Smily
Old 09-07-2002, 09:46 AM
sovereign
sovereign's Avatar
Profile:  mill springs, North Carolina
that's the way the waterpump sounds on my wife's 36ft fourwinds,but it uses one of those surflo pumps, the kind where the motor and pump are one assembly.but the pump on my a/s is belt driven and right now it does'nt work. well it runs and i can see water trying too fill the see thur filter ,but it can't make it . do you know what the problem could be?
Old 09-07-2002, 01:04 PM
uwe
418
uwe's Avatar
Profile:  1963 26' Overlander
1958 22' Flying Cloud
1963 19' Globetrotter
Portola Hills, California
Status: Online
Hi Smily,
It's not the impeller making the hammering noise, but rather the impeller compressing the water, pumping it, that is causing a strong pulsation in the copper lines, which in turn causes the lines to rattle. You might try and find the places where the lines rattle against the trailers interior, and put foam or other dampening material around it, or secure them better. The accumulator typically goes near the pump, and it's job is to store pressurized water, so it can deliver instant water pressure without the pump having to start up immediately. I believe that the water hammering suppression is almost like a pleasant side effect of the accumulator. The bladder inside it absorbs and neutralizes the water pulses, much like a shock absorber.
I hope that the accumulator installation together with securing your copper water lines inside tha trailer will make the water lines nice and quiet, so your infant will also enjoy airstreaming !
Uwe
Old 09-09-2002, 06:15 AM
smily
"Still Working"
smily's Avatar
Sovereign
Sovereign,
Yes I think I know what the problem is. I had the same situation.
All of the valves under the sink, ( three in my Overlander), have to be in the shut position. if any of the valves are open, the pump will run but will not build up pressure.
I am not certain if all valves have to be closed but I know that at least one of them is crucial to operation of water being pumped from the resevoir. I know that is sounds wierd but the valve that I have to insure is closed is the one that actually goes to the resevoir, at least it looks like it does.
I believe two of the three valves are for draining and winterization.
Give it a shot with all of the valves closed.
Good luck,
Smily
Old 11-05-2002, 09:04 AM
smily
"Still Working"
smily's Avatar
Question Acummulator installation
Okay,
Been a while since this thread originated but i have finally bought an acumulator at the Rally flea market this weekend.
It is the Shurflo model.
I got some advice on pressurizing the unit to 20 lbs with a bicyle tire pump but I am going to ask the Jury again about the locaion f the accumulator to be installed.
I see where UWE says to install near pump but I checked a site on Water hammer disipation and they said to install half way to farthest valve.
I am ready to install but I am looking for opinions on where to install the unit.
Any takers?
Smily
Ken Smillie
My 1994 36' Classic MH is for sale
See it in the classifieds
Old 11-05-2002, 09:29 AM
Action
Moderator dude
Action's Avatar
Profile:  1966 26' Overlander
Phoenix, Arizona
Location, location, location
Ken,
I have seen accumlators mounted in boats in a variety of locations. However most have been near the pump.
>>>>>>>Action
1966 Mercury Park Lane 4 DR Breezeway 410 4V, C-6, 2.80 - towing a - 1966 Overlander International Twin Bed
1996 Lincoln Mark VIII Diamond Anniversary 4.6L (275hp), 4R70W - 1990 Ford E 150 5.7L, AOD, 3.73 ____________________________________
Phoenix ~ Yeah it's hot however it's a dry heat!
Old 11-05-2002, 09:33 AM
uwe
418
uwe's Avatar
Status: Online
Accumulator
Smily,
I figured it is supposed to go near the pump, because this is where you can get to it easily, and it's also where it's shown on the literature. It probably matters only little where it goes, as the pressure surges are in the entire water supply. But if they originate from the pump, then the accunulator should be close to it as to neutralize the water pulses. The accumulator will also store a little bit of water under pressure, so initial flow at the faucets should be smoother, with the pump running a little bit less, especially when usng the faucet for short times only.
Good luck!
Uwe
Old 02-06-2003, 05:32 AM
smily
"Still Working"
smily's Avatar
Accumulator magic
I finally installed that accumulator and it worked GREAT!
I mounted it right next to the pump under the galley sink.
I also mounted the whole assembly to a rubber pad. The pad is about 1/2 inch thick and dense.
You can hear the pump but absolutely no water hammer.
Smily
Ken Smillie
Old 02-08-2003, 04:18 PM
trailertrash
Profile:
Those ShurFlo's are pretty nasty- depending on how old they are. Whenever I replace one, I use the one that is tops in the yachting industry, made by Jabsco, and the prices are about the same. I use one that pumps 3.5 GPM, so I have nice pressure, and its totally quiet compared to the Hammer- you can hear it buzz, but no pulsating, and it draws less amps. When a ShurFlo fires up, all the lights flicker and you think the world is coming to an end!
I get mine from www.lewismarine.com
If you want to try a great portable water softener, which gives great showers and removes all that calcium that damages your polished aluminum- www.softwetspot.com
vB code is On
Pingbacks are On
water system mystery garymacf Plumbing - Systems & Fixtures 4 06-21-2003 11:50 AM
Could Water Heater Tank Be Filled with Junk? heyskipper Water Heaters, Filters & Pumps 4 03-17-2003 07:26 AM
travelling w/out water system maznblu Fresh Water Systems 6 09-09-2002 12:03 PM
Water Hammer melprice Water Heaters, Filters & Pumps 10 07-30-2002 01:10 PM
Looking for ideas hot water FrankR Water Heaters, Filters & Pumps 3 05-09-2002 10:28 AM
Powered by vBadvanced CMPS v2.1.0
Powered by vBulletin® Version 3.5.8
SEO by vBSEO 3.0.0
Airstream is a registered trademark of Airstream Inc. All rights reserved.
Airstream trademark used under license to Social Knowledge LLC.
Wikipedia about Airstream - Airstream Central - Airstream Photos
