03-25-2019, 07:05 PM
2003 Bambi 19’
2017 25' Flying Cloud
Crested Butte
Water Filter System Under Sink
I have a 2017 Flying Cloud 25 FB and would like some recommendations on under the counter water filtration systems.
Michael
#simply.marsee
03-25-2019, 08:06 PM
2016 26' Flying Cloud
Southlake
I have a Seagull IV and it is supposed to be the best. A little pricy, but what is clean water worth?
2016 Flying Cloud 26u
2017 Silverado Duramax 4x4
Equalizer Hitch
03-25-2019, 08:38 PM
2015 27' Flying Cloud
Newberg
, Oregon
If you want good water it will be expensive to get it under the sink, because of the lack of space. If you put the filters outside the trailer, you can get good water for much less money.
Mike
2015 27ft FC FB
WBCCI #3960
2019 F150 ecoboost
03-25-2019, 08:58 PM
2017 25' International
Niagara-on-the-Lake
, ON Canada
I also use the Seagull IV. It easily mounts under the lavatory countertop.
Purifies water instantly
Removes: bacteria, cysts, giardia, crypto, viruses, particles, tank taste, odors, specific organic chemicals
Ray B.
03-25-2019, 09:02 PM
2022 25' Flying Cloud
NCR
, Ontario
we use a triple filer just for drinking water
and a whole house main filet. its is HIGH flow style for all water entering
03-26-2019, 06:44 AM
2003 Bambi 19’
Crested Butte
Did you add a new separate faucet or connect it to the kitchen sink?
03-26-2019, 07:47 AM
Niagara-on-the-Lake
, ON Canada
Seagull IV - Under Counter Install
The kit comes with a separate faucet and I just tee'd off the cold water line under the lavatory counter. I put a shut-off valve in the line to the Seagull IV to make winterization easy (just remove the filter.)
It is small enough that it could be installed under the galley counter, but we felt that it was more convenient in the lavatory for brushing teeth etc. It is handy to fill the kettle there for making coffee and tea too.
Ray B.
03-27-2019, 06:04 AM
2014 27' Flying Cloud
Stowe
, Vermont
The under the galley sink filter was a pain to take off every winter, and put in the bypass pipe, and return the filter in spring. Now I just keep the bypass pipe in year round, and hook up a filter at the city water source out side the AS. Now all my water is filtered.
03-27-2019, 06:07 PM
NCR
, Ontario
my triple filter is behind the uwave
it goes to a separate tap
its is VERY easy to dismantle.
each of the three cartridges come off with a simple push of a button
here is the water supply connect with a shut off valve
03-27-2019, 07:24 PM
2019 30' Classic
Canfield
, Ohio
"At some point, throwing money at the problem *is* the right answer", Uncle Bob
x\x/x\x/x\x/x\x/x\101970\x/x\x/x\x/x\x/x\x/x\/x\x/x\x/x
Tom & Doty
2019 Airstream Classic 30 Twin
04-01-2019, 07:15 AM
2003 Bambi 19’
Crested Butte
Attachment 336589
Attachment 336590
Attachment 336591
Attachment 336592
Can this filter system be connected to the main faucet cold water vs. installing a separate drinking water faucet?
04-01-2019, 07:24 AM
Niagara-on-the-Lake
, ON Canada
For a typical RS-1SG cartridge the average life is 1,000 gallons and you would run through a filter fairly quickly running all of your sink water through it. You would need some adapters to put in line with the regular cold water line.
Is there a reason that you wouldn't want the dedicated faucet? You can place it anywhere that you want on the counter top.
Ray B.
04-01-2019, 09:58 AM
2007 27' Classic FB
Ridgefield
We had the Delta PUR in our 2007 Classic. Really liked it till it died. Unfortunately Delta doesn't make that model anymore. Installed an inline filter which works fine but it is a real pain in the neck to replace.
John
04-03-2019, 08:53 PM
Vienna
, VIRGINIA
Just ordered one of these...filter the intake line on the interior.
2001 Ford Excursion 7.3L
04-04-2019, 06:36 PM
NCR
, Ontario
make sure its HIGH flow
or
you will not get enough flow. ie just enough for the tap only
04-05-2019, 04:30 PM
Vienna
, VIRGINIA
Claims to provide 6.5. GPM output flow. Will be putting it to the test in a few weeks so we shall see and report back.
04-07-2019, 11:50 AM
1978 25' Tradewind
Metro Phoenix
The real answer to your question is - as is so often the case - another question:
Why do you want to filter the incoming water?
If you're concerned about disease organisms, boil the water. No filter should be relied on for life safety. Better yet, boil and chlorinate. Or bring water from a known good source.
If you're looking for better flavor (or no flavor), a carbon filter will do that for you.
If you just want to keep out dirt particles, get a 5 micron sediment filter unit.
04-07-2019, 06:53 PM
2016 28' International
Long Beach
I love my ClearSource. Tested it at a place where we go to alot before the family would not drink the water with the old filter (.5 microns) vs. .05 with the clear source- no more water bottles. It wont remove fluoride if that's an issue.
The Wood Family
Mike Lisa & Aidan
2016 International Signature 28
2017 GMC Denali 2500HD Duramax Diesel 4X4 Crew Cab Z71
WBCCI #21506
04-08-2019, 05:00 AM
Vienna
, VIRGINIA
Good to hear Airwoody.
04-08-2019, 07:56 AM
2016 25' Flying Cloud
Frisco
Hi! What size berkey did you get? Thanks!
