04-23-2019, 07:11 PM
2022 25' Flying Cloud
NCR
, Ontario
update water system: dual high flow filter
last year i added a single high flow filter to the AS 22FB
it worked very well
it was on sale , so i picked up a second unit
the are in series
1st watts pressure regulator
2nd particulate filter
3rd carbon filter
all AS water goes through these two main high flow filters
there is a 3.5" 1"ID steel pipe between them to ensure little pressure loss
plus a separate low flow triple filet for the kitchen , just for drinking water. it has its own drinking water tap
04-24-2019, 11:17 AM
2020 19' Caravel
SANTA MARIA
Interesting, don't think we have the room for this though
2020 Caravel 19cb
Haven't arrived but well on our way!
KK6YFG
Central Coast of California
Calvary Chapel of Santa Maria
04-24-2019, 12:21 PM
2018 22' Sport
Blue Sky Ranch
it worked very well
the are in series
3rd carbon filter
I have this system under the kitchen sink at home. Must use to get RO water to prevent kidney stones. Never thought about it for the AS. We just pack 4 gals of RO from home to take on the road for drinking. All else, normal camp water is ok.
M!ke
2019 Tiffin Wayfarer 24TW
Ham Radio Call sign K5FT
04-24-2019, 01:28 PM
Aluminut
2004 25' Safari
Sort of a dumb question, but why the pressure regulator? Do the 22s not have built in city water pressure regulators like the other larger Airstreams?
04-26-2019, 07:25 PM
NCR
, Ontario
it was a lot of work with measuring and test fitting
but is was able to squeeze in the dual filter
in a week or so when i have time, i will complete the water connections
i will also clean up and replace the flex furnace hose with solid pipe for better flow velocity
re water pressure, i want to ensure if the AS regulator fails, i don't blow the system. Watts is a BIG high quality name in the industry. along with the gauge , i can tell is i have very low pressure also
05-04-2019, 07:55 PM
NCR
, Ontario
i finished running the new water connections
its a tight fit - the pressure regulator is near the toilet
- the two water filters are on the inside hall wall
- you can see the winter/summer shut off valves
- i have been replacing the cheap plastic elbows with new brass ones
05-29-2019, 10:07 PM
2016 30' International
redondo beach
Now that is some fancy plumbing!
Looks great!
Randy and Beth 15 F250, 16 30' International, ProPride, Dexter 3" lift, Michelin 16, Dill TPMS, Centramatics, Battleborn x4, Victron BMV and 1.2KW inverter, Orion DC/DC, BlueSolar MPPT, 300W solar, Alpine iLX, Polk MM1, Samsung smart 42"
