Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Water Heaters, Filters & Pumps
Old 02-08-2018, 04:24 PM   #1
2008 25' Safari FB SE
El Cajon , California
Sporatic burning water heater
Or I could say erratic burning! I have an Atwood Model G6A - 8E water heater in a 2008 Safari. When the bathroom switch is turned on - it ignites immediately but then "flames out". The igniter fires immediately and after a varying number of attempts the heater re-ignites. However it will in seconds to minutes shutdown again and go through the same re-igniting procedure. While it is running the burner "spits" (not a solid burn). I have cleaned the unit and can't find any obstruction in the gas nozzle or burner tube. I've tried operation with the door open but it doesn't change anything. With time and patience (and uncountable restarts) it will ultimately heat the water and shut off as required.
Pullingtin is offline   Reply With Quote
Old 02-08-2018, 04:56 PM   #2
2007 22' International CCD
Blow some air through the tube (flue) that goes through the tank, or run a brush up it. Sometimes bugs build a nest in there, especially Mud Dauber wasps. If its partially blocked it may not burn right.
Wear eye protection if you blow air through it....stuff flies out at high velocity...
Check the position of the flame sensor if you have electronic ignition. If its not in the right part of the flame it can act weird.
Burning Man 2004: Burnstream Court Jeromepix Our Community 38 06-14-2011 09:27 AM
Bowen water heater door with newer suburban water heater durans54 Water Heaters, Filters & Pumps 37 11-19-2008 07:17 AM
Going to Burning Man? AYRSTRM2 Other Rallies & Events 61 10-01-2007 11:47 AM
Does burning propane =water? Dan S Furnaces, Heaters, Fireplaces & Air Conditioning 10 05-27-2007 11:21 AM
Burning Man 2005 markparker22 Other Rallies & Events 8 01-08-2005 07:26 PM
