Old 02-08-2018, 02:00 AM   #1
2017 27' International
Bothell , Washington
Truma warmup times on-shore power vs. not
Bit of a strange behavior we are observing with our Truma AquaGo Comfort where when we are hooked up to shore power the Truma can take between 2-3 gallons of water run through it to actually get warm enough to start a shower, while when not hooked up it takes less than 1 gallon. Does anyone else experience this odd behavior?
Anything I might be able to debug to figure out why this is happening? I don’t believe the Truma has an electric water heating element, only propane, so I don’t think it’s that..
Bryan
lcd32bit is offline   Reply With Quote
Old 02-08-2018, 09:45 AM   #2
Airstream Ambassador
AirstreamInc's Avatar
Jackson Center , Ohio
Hi lcd32bit,
Please call our customer service and technical support team at*1 (877) 596-6111, option 2 so we can learn more and help.
Thanks.
Official account for Airstream, Inc.
Airstream Customer Service and Technical Support can be reached at 1 (877) 596-6111, option 1.
AirstreamInc is offline   Reply With Quote
Old 02-08-2018, 10:01 AM   #3
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
We have the Truma AquaGo "comfort" model in both our 2015 23D International Serenity and the 2014 31' Classic. Shore power has nothing to do with our model Truma water heaters. They take a little 12Vdc from the battery for the control circuitry and use only propane to heat the water.
There is a two way switch of "economical-off-regular" and the difference is how hot the holding tank (about 12 ounces) is maintained. The regular mode keeps the holding tank about 130 versus 100 degrees F. The amount of cold water is the length of pipe from the output port of the water heater to the shower or faucet.
Truma WH owners, worth it? lsbrodsky Water Heaters, Filters & Pumps 21 04-26-2020 12:43 AM
Truma AquaGo tankless water heater waninae39 Water Heaters, Filters & Pumps 41 05-06-2019 09:00 AM
Max incoming psi for Truma Combi water heater Bborzell Base Camp 3 06-09-2017 11:16 AM
Truma Info? DSM2570 Modifications 2 01-15-2016 04:17 PM
Instead of a Generator, Truma launches VeGA nmayer1 Electrical - Systems, Generators, Batteries & Solar 2 11-15-2012 09:54 AM
