Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Water Heaters, Filters & Pumps
Old 04-14-2003, 12:34 PM   #1
JimC's Avatar
Images: 14
Question Peters & Russell parts needed
Anyone know where I can get a diaphragm and set of valves for a Peters and Russell pump in a 67 Tradewind?
JimC is offline   Reply With Quote
Old 04-14-2003, 02:58 PM   #2
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Lutz , Florida
Images: 21
Send a message via AIM to thenewkid64 Send a message via Yahoo to thenewkid64
Try this Link
Airstream use many of the same components as the marine world.
Good Luck
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 04-14-2003, 07:00 PM   #3
1962 19' Globetrotter
2001 31' Excella
Jim,
I was able to purchase new diaphrams and a bottom plate for my old PAR 36800
pump from:
Jabsco Service
11-35 Commercial St
Cypress Rd
New Bedford, MA 02741
508-992-8084
Ask for Roger. He was a great help when I called.
Craig
Craig is offline   Reply With Quote
Old 10-24-2011, 01:02 PM   #4
Ty
denverdingo's Avatar
1967 22' Safari
thornton , Colorado
P & R 36800 Pump - Keep it or replace it.
I know this thread is old, but hoping to get some experienced advice. I pulled out this pump and it's a unique looking thing, and I'm thinking it can't be efficient. I wouldn't drink water that ran through it without total overhaul/cleaning whathaveyou.
BUT, I can tell this thing has some value to the overall '67 Safari.
I don't want to get rid of this pump unless it goes with the trailer one day. But I don't think this is practical for water output and dc consumption.
Would it be practical to shelve it until money is flowing and then turn it on its head and make an auxillary 'draw pump". There are often icy cold fresh water springs coming off the mountains...could just make a intake pump, keep it for aesthetic/preservation value.
Thanks for your thoughts.
Ty
ID:	143577   Click image for larger version
ID:	143579   Click image for larger version
denverdingo is offline   Reply With Quote
Old 10-24-2011, 02:18 PM   #5
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 194
Greetings denverdingo!
Welcome to the Forums and the world of Vintage Airstream ownership!
Ty
What you have is a PAR water pump that may very well be original to your coach. The last time that I checked, rebuild kits were still available. While many RV dealers won't recognize the pump, a marine dealer will readily recognize the pump and will likely be a better source of replacement parts. I have made it a practice to keep a rebuild kit as well as a small replacement parts kit in each of my coaches. The Airstream Service Center that performs most of my repairs has been able to source the rebuild kits as well as maintenance parts for me. Rebuilding and maintenance of the pump is comparatively simple even for someone with limited do-it-yourself inclination as am I. I don't have any reservations about using water pumped through my PAR as it is fully exposed to the sanitizing solution each time I santize my fresh water system.
Good luck with your coach!
Kevin
Kevin D. Allen
WBCCI (Lifetime Member)/VAC #7864
AIR #827
1964 Overlander International
