I just bought a 1991 Excella 1000, 34', but when I hooked up the water, I had a problem. After tracing the problem down, I have a parted hot water line, down stream of the water heater but up-stream of everything else. Is there a schematic available of the hot water system?
If you can locate the service manual for your unit, it should give you a clue.
Are your water pipes copper??? Bet they froze..Worse comes to worse pipe air or water backwards from a fawcet, see where it comes out.
The pipes are plastic. It comes out somewhere between where it goes onder the floor towards the kitchen area and makes the turn near the pump. I have a service manual for the years 91,92 & 93, but it doesn't have a schmetic of the piping and where it runs. My guess is that they either froze or a creature chewed thru them while it was un-used for two years before I bought it.
