Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Water Heaters, Filters & Pumps
Old 11-11-2015, 12:23 PM   #1
Clyde , North Carolina
Gas water heater will not shut off.
The electronic ignition ignites hot water heater with a bang. Then the water heater continues to run after switch is turned to off position in camper. Only way to stop burner from running once lit is to shut propane off to entire camper. To me this says gas valve at water heater is staying open at all times. Now what is you idea to resolve? It's an old camper so I expect I need to replace a component on the heater but where to start?
Wycolo is offline   Reply With Quote
Old 11-11-2015, 12:32 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
To test the gas valve pull one of the wire of the valve while the heater is running. If the heater stops the control board was calling for heat. If with the wire off the gas valve may be mechanically stuck open. Not likely because the gas valve has 2 spring vales in it and the likely hood that both could be stuck open is slim.
Another thing to check. There are 2 klickons on the face of the heater that are wired in series. Pull any wire in that series and see if the heater stops. If it does stop the high limit switch has welded closed. They are replaced in a set.
2004 Excursion 4x4
Old 11-11-2015, 01:03 PM   #3
2007 22' International CCD
Also verify that your regulator is putting out the correct pressure. If the gas line is running too much pressure you will get a pop when it ignited. Need a propane tech with the right gauge to check this.
Is the stove and fridge behaving normally?
93 Hot Water Heater Propane Shut off Lumatic LP Gas, Piping, Tanks & Regulators 0 06-08-2015 11:19 AM
Water heater shut off valve...where is it? ole81 Water Heaters, Filters & Pumps 19 04-05-2014 03:19 PM
Water heater won't shut off 58cruzer LP Gas, Piping, Tanks & Regulators 6 05-18-2013 05:31 AM
Water heater does not shut off (NEED REMEDY) Ttuck118 Water Heaters, Filters & Pumps 3 07-12-2010 03:38 PM
Water heater thermostat does not shut off gas to burner davelance01 Water Heaters, Filters & Pumps 2 06-12-2009 09:55 AM
