Voids The Warranty!!
If you're talking about the 'Hott Rodd' or similar device, it's use will void the warranty on new heaters. The idea is sound, but I have seen folks with problems and removed them. Thermostatic control failure is usually the culprit.
If you are using it on a Suburban, it has to replace the anode in the drain plug which protects the tank from corrosion. I would NOT recommend this for a Suburban.
Check with Atwood and they will say that they also don't suggest them.
lewster
