Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Waste Systems, Tanks & Totes
Old 02-17-2019, 06:50 PM   #21
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
1969 21' Globetrotter
Conifer , Colorado
Welcome to Air Forums. Valterra 3" blade valves are available over the counter at most Camping Worlds, RV dealers, or on line. They come as a "center valve assembly" and then the style of connections you might want. A "hub" allows a 3" ABS pipe to fit into it, a "spigot" allows a 3" ABS pipe to fit over it. Standard ABS glue is use to assemble the piping.
On my trailer, the valves are assembled in the drain manifold. The 3" pipe fits into the tank boss. I used a butyl sealant, slipped the ABS pipe into the tank boss, and then tightened the hose clamps. See photo.
Hope this helps a bit.
David
Name:	1205 New Valtera Black Tank Valve-800x600.JPG
WBCCI #8607 VAC Region 11
KnowledgeBase trailer renovation threads: 69 Globetrotter, 76 Sovereign, 75 Overlander, 66 Trade Wind Such fun !
Holding Tanks Drain - Thetford to Valterra Rebuild dbj216 Waste Systems, Tanks & Totes 5 06-08-2012 03:34 AM
Opinions welcomed.. Valterra or Thetford Phrunes Waste Systems, Tanks & Totes 13 08-20-2011 07:40 PM
Valterra to Thetford connection Craig Waste Systems, Tanks & Totes 30 03-05-2011 07:49 PM
Replace a Thetford Valve with a Valterra? thunder433 Waste Systems, Tanks & Totes 2 03-03-2008 04:41 PM
Thetford vs Valterra pilgrim_still Waste Systems, Tanks & Totes 8 06-11-2005 01:34 PM
