I noticed on the tank shroud that is bolted around the waste tanks that there is a weep hole. After driving through rainstorms today for the first time I noted water draining in drops from the weep hole and around the flat aluminum sheets that are forward of same. Not a lot and over the last few hrs is has slowed to almost a stop.
Crawled under and found open areas between front stabilizer and shroud - appears sealant fell out?
Did the obvious checks inside with no signs of plumbing leak. As this is a FC 27FB most of the plumbing is rearward half of trailer.
Comments and suggestions welcome - we are home and have the full shop of tools
My suggestion is to add weep holes to make sure no water is trapped in the underbelly. Years ago, I drilled 1/8" holes in all of the low spots in the belly pan after finding trapped water by accident.
