Old 01-30-2013, 02:05 PM   #1
1994 34' Limited
Griffin , Georgia
Sewer connection help
I have a 18' Globtrotter and can't find a sewer connector that will fit. My connector is aluminum and has a large gasket. I want a regular banet connector where I can connect a regular sewer hose. Coming out of the trailer inside measures 2 3/4" and outside measures 3 1/4". Inland RV sent me a Thedford which is too big. Any help would be appreciated. Thanks
bwpjcms is offline   Reply With Quote
Old 01-30-2013, 02:54 PM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
A picture would be helpful. Most equipment of that era used Thetford fittings as far as I know. How is this aluminum device fastened to the sewer pipe?
Old 01-31-2013, 09:14 PM   #3
1963 19' Globetrotter
Orion , Illinois
If you have the cast connection for the old Thetford valve ,simply use a Fernco connector and a couple of hose clamps to attach a new sewer fitting of your choice to the the old connection. Not pretty but works like a charm.
63air is offline   Reply With Quote
Old 07-24-2014, 09:48 AM   #4
1955 22' Safari
Laredo , Texas
I had the exact same issue/solution on my 64 Bambi ll. My buddy just purchased a 64 Overlander and has the same problem but does NOT have the original aluminum connector. Anybody have one for sale?
55AS is offline   Reply With Quote
Sewer Hose & Coupler wlanford Waste Systems, Tanks & Totes 85 05-24-2016 08:20 PM
City Water Connection gaylejoe Fresh Water Systems 10 04-13-2015 12:59 PM
Newbie dumb question re sewer hookups Rich of SCal Waste Systems, Tanks & Totes 62 02-23-2012 07:12 AM
Newbie ? Home sewer clean out Bigcgar On The Road... 15 04-30-2011 05:55 AM
Need Help with a Spare Wheel and Sewer Hose for Int'l 19'? jambie 2005 and newer - Bambi all models 4 03-07-2011 07:50 PM
