10-28-2012, 03:10 PM
#41
1993 34' Excella
Estancia
, New Mexico
Originally Posted by beckybillrae
. I lost a toothbrush in my trailer the first day or two that I had it! I did a lot of digging in that black tank!
I would hate to loose a perfectly good toothbrush
10-28-2012, 03:24 PM
#42
Normal
Congratulations on your success!!
Maggie
10-28-2012, 03:54 PM
#43
1972 23' Safari
Cleburne
Thanks. I learned a lot of leasons to day! The hard way! So they wont be forgotten. Everything has been bleached and freshened up. So all is good in my lil space shuttle now!
10-28-2012, 03:56 PM
#44
1972 23' Safari
Cleburne
Also, just so i understand. With the gate closed, the shower and sinks still drain freely down the slinky. Correct?
10-28-2012, 04:12 PM
#45
1993 34' Excella
Estancia
, New Mexico
When the black tank gate valve is closed there is no way for the #2 to upchuck through the shower sink drain.
Congradulations again! Don't let anyone ever tell you you don't know ****. Nothing feels better than a good dump.
10-28-2012, 05:05 PM
#46
1960 22' Safari
in the wilderness
, The great Mojave Desert
Ok, I got it fixed! Went and got some rubber gloves, and did the nasty! It was blocked right at the danged fitting! Just like someone said. I tell you one thing, those tanks hold a quit a bit of pooo. When i pulled that sucker loose, the valve was open! I know i was told! I forgot! I paid! Had to flood all around my trailer with fresh water.. Going to get some bleach now, to douse the ground with, to kill the smell. There was a gob of paper and nuggets hung up right at the connection. How do i avoid that in the future? Do I need to keep the waste gate closed, until the tank is full, then dump it once in a while? I think someone mentioned that? Yes this is the first time I have had this rv out. No, I have never had one set up in a park. They are always at the deer lease, with an out house in operation. Please give me all the info you can, so i can avoid this terrible, terrible situation again. Thanks
I'm not gonna lie. I laughed a lot reading this. I guess I'm going to hades...
Glad it all came out in the end...
I'd rather be boon docking in the desert.
WBCCI 3344 FCU
AIR# 13896
CA 4
Yes, we have courtesy parking for you. About an hour North of Los Angeles.
10-28-2012, 06:43 PM
#47
1977 31' Excella 500
West Sacramento
Consider yourself initiated into the fraternity of RVers.
10-28-2012, 07:16 PM
#48
1965 17' Caravel
1983 27' Excella
Walnut Grove/Laguna Woods
Correct.
Keep the dump valve closed until you want to dump the black tank. If you are leaving your hook up space and want to dump, be sure your black tank is full or nearly full, If it is not, let water run into the black tank to near capacity, then pull the valve. That will allow the "Whoosh" which will carry most everything right down your slinky.
Since you don't have a gray water tank to empty to wash out your slinky, you may want to again fill your black tank and drain it again. You can also put stoppers in your sinks, fill them, and with your black tank valve pushed shut, let the sinks drain to help clean your slinky.
10-28-2012, 07:22 PM
#49
1972 27' Overlander
Longmont
Yes. The only thing that would keep the sink/shower water from draining out of the trailer would be if you did not have the slinky attached, and you had the drain cap screwed on. You do NOT want to ever do this, because that water will also very quickly back up into your shower.
When I bought my trailer, the seller said he had emptied the black tank. I got home, started looking things over, took the drain cap off, and pulled the black tank valve handle. (Why? don't know..) The seller was a liar.
10-28-2012, 07:41 PM
#50
1966 22' Safari
Hilltop Lakes
Gray water lines
All there is, is one drain. And it comes straight down, directly out of the dump valve. T'd off to the left and right just below the dump valve are 2 1-1/2" lines.
Those smaller lines that connect downstream of your dump valve are the gray water connections. They're open all the time, unless you have the cap on the sewer connection for travel.
10-28-2012, 09:25 PM
#51
1993 34' Excella
Estancia
, New Mexico
Originally Posted by dougsale
consider yourself initiated into the fraternity of rvers.
baptized
10-28-2012, 09:34 PM
#52
Ottawa
, ON
That were a good'un!
“Courage is being scared to death, but saddling up anyway.” ...John Wayne...........................
10-29-2012, 05:38 AM
#53
2005 30' Land Yacht 30 SL
Rockford
, Michigan
Search "Geo Method"...it's a technique to clean the tanks, lines & valve. Also helps keep it clean & helps prevent clogs & bad odors....there's a detailed how it works somewhere on the forum. Basically, dissolve 1 cup laundry detergent & 1 cup calgon in hot water, pour into the toilet, flush into the tank & let it work. Do this every time the tank is emptied. Easy!
10-29-2012, 08:43 AM
#54
2015 25' FB Eddie Bauer
2013 25' FB Eddie Bauer
2012 20' Flying Cloud
Small Town
Just remember that old poo not dumped regularly has a way of rhickening / re-solidifying and you can then end up in the same situation again. Over time, some of the moisture will evaporate through the plumbing / sewer vent pipe ...
