Old 01-14-2008, 12:17 PM   #1
More than one rivet loose
thecatsandi's Avatar
Los Alamos , New Mexico
My Black tank leak
Well here I sit at North Dallas RV. It took a while but they found the leaks. Yes two of them. The first leak came from the seal between the toilet and the toilet flange. This is where the water is coming into the trailer. The seond leak was more elusive. The threaded flange in the tank that the toilet flange screws into is seperated in for left side of the tank. THe cause: Probable overtightning of the toilet flange.
First option. Replace the tank. Second, repair it with epoxy or plastic welder.
I was present them Randy of North Dallas was talking to the factory. I agreed to have it repaired over replacement. Two reasons: One it was going to take several days to get the tank here. Read several days in a hotel at my expense. Second: it is going to snow in a couple of days. I really do not want to be here when that happens.
Fixing the tank is cheaper for the factory. In exchange if the fix fails within the next 5 years they will replace the tank.
I hope to back on the road this afternoon.
Michelle TAC MT-0
Sarah, Snowball
thecatsandi is offline   Reply With Quote
Old 01-14-2008, 12:28 PM   #2
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
Safe travels Michelle, to me you made a sound judgement call on the fix over replacement in light of the 5 year replacement option. Gets you back on the road faster.
BTW - my boys are still looking for your cat.
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
clancy_boy is offline   Reply With Quote
Old 01-14-2008, 12:42 PM   #3
_
it's nice 2 have the extra years protection...
but get it IN writing. because the 'creative warranty' issues are dependent on 1 or 2 people that work in j/c still being there...
i'm skeptical this repair will work long term, but understand about not wanting to wait for a tank.
does't the notion it's 'loose at the seal but so tight it cracked' seem a bit like double speak?
yes over tightening at the toilet may be part of the cause...
but the tank support/banding may NOT be snug enough up to the flooring/frame...
so that when ever the tank has much content, it starts to pull DOWN away from the toilet...
IF your tank is hanging at ALL by the flange area, there will be recurrent issues...
so ya better think hard about keeping it very empty when traveling...
thanks for the update on your poo pot...
too bad we don't use litter boxes
cheers
2air'
Old 01-14-2008, 01:21 PM   #4
. , At Large
From someone that just had their toilet out...
It is possible to not have the toilet tight enough on the closet flange, but to have the closet flange too tight going into the tank. They are two seperate places that need tightening. Not too much, not too little, but just right, like Goldilocks and the three leaks.
Old 01-14-2008, 01:48 PM   #5
_
Originally Posted by overlander63
...It is possible to not have the toilet tight enough on the closet flange, but to have the closet flange too tight going into the tank... like Goldilocks and the three leaks.
gotcha, that makes sense.
yea i've had the honor of replacing the toilet 3 times in the last 2 years...
including one shipped 3000 miles 2 me. u should have seen the commotion at the post office...
when i walked in and asked....
"i'm here for my general delivery mail, have you got a toilet bowl for me?"
not only are the attachments different but length of the lag screws used is critical...
the ones that came with the sea-land pots are too long and if used correctly can penetrate the flooring and the tank...
which makes for another occult odor source....
cheers
2air'
Old 01-14-2008, 04:34 PM   #6
I will. A letter to the warrenty department is coming with a copy to VP Customer service.
I saw the problem and the solution. I am confident the tank repair is going to work. The toilet flange was pulling up on the tank flange. Add the wieght of waste and you are in for aproblem. The toilet flange does not need to be that tight. Plenty of goo on the seal.
There is no band. The tanks sits on foam in a pan bolted to the frame.
If your tank is hanging at ALL by the flange area, there will be recurrent issues...
I am aware of it
This is not always an option.
Michelle TAC MT-0
Sarah, Snowball
Old 01-14-2008, 04:38 PM   #7
THe guy working on my trailer is quite good. I saw the sael between my toiler and the flange. It as not sealing as well as it should. It was replaced.
When I got back from shopping. They had the toilet and tank in. They were leak testing. I was hopeful about getting out of here this evening. We still have one small leak. I am spending the night in the Rv parking lot and hope to be out of here in the morning.
Michelle TAC MT-0
Sarah, Snowball
Old 01-14-2008, 04:39 PM   #8
Originally Posted by clancy_boy
S
They are going to have to look a long ways!!!! She is in Dallas now!
Michelle TAC MT-0
Sarah, Snowball
Old 01-14-2008, 04:45 PM   #9
clancy_boy's Avatar
Kiln , Mississippi
Images: 8
Now they know where she is - they have internet in the dog house....
I see them looking at MapQuest now for directions......
Tina says hello.
Mike
Old 01-14-2008, 07:17 PM   #10
SafariSS's Avatar
2005 30' Safari
Houston Texas , Texas
North Dallas..
Randy is quite the good tech. If you ever need sheetmetal replacement he is the guy. I have seen alot of his work as the shop is very busy and when he is done it looks great.
Facility is not real "customer friendly", kinda shadetree, but he does nothing but Airstream warranty work/repairs.
SafariSS is offline   Reply With Quote
Old 01-14-2008, 09:20 PM   #11
pcasa's Avatar
1966 17' Caravel
Dallas , Texas
good luck Michelle
It was nice meeting you today at North Dallas RV - as I mentioned, Randy will be doing the restoration on my Caravel. I was very impressed with him - he does all the body panels by himself and appears to be a craftsman/perfectionist extraordinaire. And just so you know, you're the first real "Airstreamer" that I have met in the flesh as my "AS dream" begins.
Save travels, paula
pcasa is offline   Reply With Quote
Old 01-14-2008, 10:17 PM   #12
holland , Michigan
interesting and I worry often traveling with the blank tank fully loaded, my issue is no grey tank, just one huge 70 gallon combined beast. How long will this last towing 16k miles /year?
safari 28 is offline   Reply With Quote
Old 01-14-2008, 10:55 PM   #13
SilverCabin's Avatar
2014 27' Flying Cloud
Viera , Florida
Traveling with the Black Tank Full?
It doesn't sound like this was caused by traveling with a full tank, at least I didn't read that in Cats' messages, so I hope that isn't something we should be concerned about. We always travel with a full FRESH water tank, and with BLACK and GREY tanks anywhere between empty and almost full. We have a dump station at our storage facility, so I generally return home with tanks ready to empty--saves time by not having to get in the dump line at the campgrounds.
Randy
Randy & Pat Godfrey
Florida Airstream Club (027)
ACI# 1212 - AIR# 17017
2014 27FB Flying Cloud - SilverCabin II
2018 F-150 Platinum - unnamed
The best part of any trip is when you pull away from home.
SilverCabin is offline   Reply With Quote
Old 01-14-2008, 11:13 PM   #14
_
folks shouldn't worry about traveling with full tanks...
IF the tanks are properly supported.
i do it regularly as well, so my intent wasn't to sound the alarm...
BUT that also assumes the belly pan/support for each tank is intact.
mine doesn't have 'foam' under the tank, but there are pieces of styrene around the tank...
these tank mostly rest on the belly pan sections of galvanized sheet metal...
anyone that has had a tank sensor replaced MAY have had a technician access the area by LOWERING the pan
this process leaves the tank slightly UN supported, until the pan is reattached...
(in fact the factory guys prefer to cut a hole in the belly pan near the sensor, rather than lowering the pan)
i've had the pans lowered AND now have holes/doors cut at each sensor just so the pan never gets lower again, for this...
sometimes techs leave out a few bolts or don't fully snug them, and some tanks DO ride loosely, the styrene moves, compresses and so on...
so my concern was related to the POTENTIAL for stress/downward force on this repaired crack...
an empty blank tank may look fully supported, but a tank filled with 250lb + of stuff ABSOLUTELY must be supported...
i didn't intend to hijack the message OR suggest the repair won't perform perfectly 4 eternity...
but i would be concerned as already explained, because once burned by this issue one doesn't forget the smell...
cheers
2air'
Old 01-15-2008, 09:39 AM   #15
Wabbiteer's Avatar
Jupiter , Florida
As important as the fittings being under a neutral tension in relation to each other is having tank solidly blocked against tank slosh providing lift while frame is descending and throwing 100's of pounds of force at finding the weak flex spots. Looking at the damaged tank in my '73 the flop 'up' motion was the culprit, the tank top flange was repaired once in antiquity and cracked again in nearly the same place. The only part I wonder about is how much flex to provide when it tries to loft up - zero or near zero. Whatever it gets will be sturdier than the pink fiberglass that was found in the air gap above the tank, foam batten cross pieces or 'L' blocks inserted around the top corners or both...
Wabbiteer is offline   Reply With Quote
Old 01-15-2008, 09:46 AM   #16
This raises an interesting point. I encouage all to fill thier tank to capacity and beyond with water. Up to the point of water left in the toilet bowl. This will test all the seals and joints.
Be sure to gently rock the trailer to burp the tank.
Let it sit for an hour. If you do not loose any water. you are good. If you do and see the leak I suggest you get it fixed especially if you are still in warrenty.
Michelle TAC MT-0
Sarah, Snowball
Old 01-15-2008, 08:29 PM   #17
Update
The tank is back in for the third time. It took three tries to find and fix all the leaks. They insalled a 1/2 plywood shim under the black tank. This keeps the tank from hanging on the toilet flange.
In all three leaks. The seperated tank flange, the seal at the toilet flange and the seal between the toilet halfs.
Wow!
I am back on the road and in Mineral Wells for the night.
Michelle TAC MT-0
Sarah, Snowball
Small leak in black water tank InspectorDread Waste Systems, Tanks & Totes 4 12-31-2007 12:13 AM
Help- leak in black tank (photos) Dan S All Argosy Trailers 12 05-06-2007 05:18 PM
Black tank leak soldiermedic Waste Systems, Tanks & Totes 2 11-26-2006 09:03 AM
Black water tank leak $$$$ wacnstac Waste Systems, Tanks & Totes 6 05-08-2006 10:50 AM
black tank leak above valve gary Waste Systems, Tanks & Totes 2 06-03-2004 08:42 AM
