10-25-2010, 08:29 PM
1964 22' Safari
Dayton
, Ohio
How do you glue ABS fitting to ABS tank?
Adding a grey water tank to a 64' Safari. The tank I ordered came with the outlet but no inlet or vent fittings. How exactly do you glue the fittings? Do you use cleaner then the ABS glue?
10-29-2010, 09:56 AM
1956 22' Safari
2015 27' Flying Cloud
Conifer/Evergreen
Yep. Just glue-up like any ABS with solvent-type glue.
Shari
10-29-2010, 11:05 AM
1984 31' Airstream310
Ajo
Keyair turned me on to a cool site. Google "mek/abs".
10-30-2010, 06:25 AM
1964 22' Safari
Dayton
, Ohio
Excellent! Thanks for the help and the search info.
11-19-2010, 11:25 AM
Foothill Ranch
Wow, Thanks Mike... I feel for once I did something to help others rather than asking for help!
Since I posted that over in my thread, I found this article that is pretty good... its for repairing motorcycle fairings, but it has a lot of good info.
http://vfrworld.com/tex_vfr/tech/plastic.htm
Now, anyone wanna tell me how to add/delete fitting from a poly tank?
LOL!
11-19-2010, 12:31 PM
1994 30' Excella
Mississauga
, Ontario
If I remember correctly polyethylene is usually welded with a hot air gun. Leister is the make of gun I have and there are attachments available to use a poly welding rod to fill the joint.
Al
Al and Jean
TAC ON-3
11-19-2010, 12:44 PM
Foothill Ranch
Thanks Al!
I have this kit already, so maybe I can use it.
Plastic Welder
11-19-2010, 05:56 PM
1970 27' Overlander
Salt Lake
, Utah
Practice
The best way is to weld the fittings in. It's a bit like oxy-acetylene welding with a hot air torch and plastic rod. If you're not familiar with this type of welding, I suggest you practice on some scrap first, there is a touch to it.
11-30-2010, 06:07 AM
1978 28' Ambassador
Savannah
, Georgia
How to take this apart
Have to remove the waste lines from the holding tanks in the back of AS. Are these connections glued to the tanks or will they just (hopefully) slide off? If they are glued, how to I remove them? Thanks. Jack
12-09-2010, 07:19 PM
1966 20' Globetrotter
Pisgah Fores
, NC
Jack,
think those fittings and pipes are glued. try hot air gun to loosen. no telling what type of glue they used in 78. you might want to consider cutting lines and then just using a slip joint to reattach if you cannot get pipes loose.
Cheers, Rob
