Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Waste Systems, Tanks & Totes
Old 06-28-2012, 08:56 PM   #21
SmokelessJoe's Avatar
1976 Argosy 24
now being enjoyed by Heath and Mary in , Vermont
The sump and barrel idea will work so long as the barrel is buried in the earth, below ground level.
SmokelessJoe is offline   Reply With Quote
Old 06-29-2012, 09:10 AM   #22
Or, (also outside the box thinking)
The grey water gravity drains, to a barrel or holding tank. But it sits on a platform, that can be raised using a 'cheap' harbor freight hydrualic jack; when your going to empty it, just jack it up, so gravity will drain it to the macerator pump? So, buy a sump pump, or buy a hydraulic jack? Whichever is cheaper, easier, more do-able.Jim
dutchdivco is offline   Reply With Quote
Old 07-07-2012, 10:05 PM   #23
1968 28' Ambassador
n/a , n/a
Sergei
Thanks so much for your reply. I think the thing to do is just what you said, maybe put in a grey water outlet. If you see of anybody whos done this I sure would appreciate the help.
Thanks again.
etanbf is offline   Reply With Quote
