Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Waste Systems, Tanks & Totes
Old 09-07-2015, 05:33 PM   #1
Bryan , Texas
Grey & Fresh Water Holding Tank Locations
1963 Sovereign trying to locate the fresh water and grey water tank. Does anyone know of where I could locate drawings or schematics plumbing?
Oldstuff63 is offline   Reply With Quote
Old 09-17-2015, 05:15 AM   #2
1962 19' Globetrotter
Seattle , Washington
The fresh water tank should be located under the front Groucho. The black water tank is located under the toilet. A 1963 Airstream did not have a grey water tank.
seawaatty is offline   Reply With Quote
Old 09-29-2015, 05:54 PM   #3
Bryan , Texas
Do you know about rewiring the 110 electrical and 12 volt?
Oldstuff63
Old 09-30-2015, 09:21 AM   #4
12v 110v systems
Email me your questions regarding the 12v and 110v systems and I will be happy to answer them. Seawaatty@aol.com
Old 10-04-2015, 09:53 PM   #5
1996 25' Excella
Julian , California
can someone tell me where the grey water tank is located on my 1971 Airstream Safari trailer? Also where is the drain plug to drain it? How can I divert the grey water from my sink straight to the outside, bypassing going to the septic tank?
1947dutchman is offline   Reply With Quote
Old 10-04-2015, 10:18 PM   #6
Glenritas's Avatar
1969 25' Tradewind
Shasta Lake , California
I think the '71 may not have a gray water tank.
Glen & Jane 1969 all electric Airstream 25' TradeWind
2014 Toyota Tundra
1998 Chevy Tahoe
WBCCI #6269
My Build Thread https://www.airforums.com/forums/f11...ml#post1997059
Glenritas is offline   Reply With Quote
Old 10-05-2015, 08:34 AM   #7
nickclifford's Avatar
1972 31' Sovereign
felton , California
my '72 Sovereign doesn't have a grey water tank i hadn't realized this until after buying it. Back in those days it was "cool" to dump shower water into the campground when boon docking.
you could divert grey into your black by leaving the valve open (this valve would be used to empty the poop tank.) water will simply back flow into that black tank. not advised if you're using the black water tank for it designated purpose though.
exit drain hole on my '72 is at the very rear by the bumper.
i'm considering installing a composting toilet and then using the black tank for grey water. until i rip under belly apart and install a gray tank, what are my options? just poop in the campsite toilets ? but if true boon docking with no toilets would be nice to use the AS toilet.
nickclifford is offline   Reply With Quote
Grey Water Tank Flushes Toilet (to conserve fresh water) LittleRadio Sinks, Showers & Toilets 10 11-14-2021 10:45 AM
Using a fresh water tank as a grey tank? Mike&Ali Waste Systems, Tanks & Totes 14 09-16-2010 10:50 AM
Ratio of Fresh Water/Grey Water Tank, Help! erikjware Waste Systems, Tanks & Totes 1 05-08-2008 10:42 AM
That pesky grey water that bypases the holding tank Van All Argosy Trailers 15 08-13-2004 07:52 AM
