Old 05-30-2005, 11:15 AM   #1
Thumbs up Getting to the Guts
What's the best way to raise the Bambi 16' to get access to the drainage lines underneath.
gbrentsmith is offline   Reply With Quote
Old 05-30-2005, 11:22 AM   #2
cosmotini's Avatar
2021 27' Globetrotter
Saint Louis , Missouri
Images: 83
Why would you have to raise it 16'?
I'm sure someone will have a non-smart-a$$ answer to your question.
Dennis
cosmotini is offline   Reply With Quote
Old 05-30-2005, 11:26 AM   #3
How about raising the 16' Bambi model just high enough to get easy access to the underside.
Old 05-30-2005, 11:34 AM   #4
1975 29' Ambassador
Reno , Nevada
The first method is to use the tongue jack to see-saw the trailer to raise the front or rear depending upon what you want to do.
The second method is a ramp. This can be out of blocks sequentially stacked. Sometimes the car ramps will fit as well and they are a bit more stable.
If you use one of these methods, make very sure that you have wheel chocks in place and the trailer is securely in place.
If these methods don't get you enough lift, you will need a hoist. This should lift the wheels. If you can't hoist the wheels, then you need to be very careful about jack placement and frame support.
Old 05-30-2005, 11:39 AM   #5
87MH's Avatar
1978 31' Sovereign
Images: 292
Here's one way
2 X 12's, all different lengths, cut at a 45 bevel and staggered.
The "rearmost" section is fabricated out of 2 X 12's and 1/2" plywood nailed together.
Name:	6 Inches of Lift with 2 bys.JPG
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
New Int'l Floorplan RoadKingMoe 2002 - 2005 International 41 03-02-2003 05:10 PM
Univolt Replacement rjones1138 Electrical - Systems, Generators, Batteries & Solar 19 10-21-2002 03:31 PM
air horns uncleneal Airstream Motorhome Forums 1 08-16-2002 07:22 AM
