Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Fresh Water Systems
Old 06-29-2013, 03:11 PM   #41
Lexington , Kentucky
Well , I have been putting up a good fight with a little mouse!!😀🐭
Lexgirl is offline   Reply With Quote
Old 09-06-2017, 06:45 PM   #42
To Gulls
To Gulls's Avatar
2007 25' Safari FB SE
Pensacola , Florida
We had a water pressure problem when hooked to city water....it was good pressure at first and then slowed to a stream on all faucets in the trailer....turned out we had black muck in the screen where the hose connects to the trailer....check that out and if dirty, take a tooth pick and clean it, rinse it and then hook the hose up. Worked great after that! We usually rinse the hose prior to hooking it to trailer to avoid this issue. So Simple but true!
To Gulls
Tami & Brenda - Pensacola, FL
2007 25FB Safari Special Edition LS
2008 White Toyota Tundra 5.7L V8
"There is no present like the time."
To Gulls is offline   Reply With Quote
Old 05-24-2018, 10:21 PM   #43
2007 27' Safari FB SE
BENSON , Arizona
water pressure in part of rig
I have good pressure coming in the rig and good pressure at bathroom and shower faucets. The faucet at the sink/galley is a trickle. The screen at the end of the faucet is clean. is there another screen in the faucet itself or further up stream?
Thanks for the help
ebiz is offline   Reply With Quote
Old 05-25-2018, 06:14 AM   #44
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Ebiz,
Welcome to airforums from our site at Virginia Highland Haven.
Water restricted at kitchen faucet. Is it both hot and cold or just one?
Ideas. Look underneath see if someone added a filter. Next is it a delta or moen single handle faucet? Turn water off, remove innards and look for crud etc.
Good luck
Gary
GCinSC2 is offline   Reply With Quote
