Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Fresh Water Systems
Old 08-08-2008, 04:32 PM   #1
64_safari's Avatar
Profile:  1964 22' Safari
Ashland , Missouri
Mystery Part
Greetings all,
Can anyone identify this part?
I'm guessing it is a visual level indicator for the fresh water tank. It was secured to the floor next to the hot water tank, but was attached to nothing. Lower end with valve ran off under toilet, upper end ran through hole in floor but did not drain outside.
Dave
64_safari is offline   Reply With Quote
Old 08-08-2008, 04:35 PM   #2
LHall's Avatar
Profile:  1962 28' Ambassador
Phoenix , Arizona
You are exactly correct. We have the same sight glass in ours that works well.
Louis & Sergio
Air #22673
WBCCI# 2731
Four Corners Unit
LHall is offline   Reply With Quote
Old 08-08-2008, 07:55 PM   #3
64_safari's Avatar
Ashland , Missouri
LHall,
Thanks for the info. The way I found it was strange, but not the strangest thing I've found!
Old 08-12-2008, 08:38 AM   #4
LHall's Avatar
Phoenix , Arizona
There is a whole thread on here dedicated to strange things found, it is pretty fun to read.
Louis & Sergio
Air #22673
WBCCI# 2731
Four Corners Unit
mystery part on 71 Trade Wind Lumatic Electrical - Systems, Generators, Batteries & Solar 13 11-26-2006 01:28 PM
Mystery Part davida Furnaces, Heaters, Fireplaces & Air Conditioning 4 08-16-2006 11:04 PM
Mystery Part balrgn Argosy Motorhomes 8 03-22-2006 07:21 AM
Mystery MH PeterH-79MH Airstream Motorhome Forums 4 01-01-2005 05:57 PM
Repost to part Forum (window part, 67 A/S) JimC Parts Archive 15 09-28-2003 09:45 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
