Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Fresh Water Systems
Old 11-18-2014, 11:15 AM   #21
DougnJanet's Avatar
2013 23' FB Flying Cloud
Kennewick , Washington
ID:	226848   Click image for larger version
ID:	226850   Click image for larger version
DougnJanet is offline   Reply With Quote
Old 11-18-2014, 01:11 PM   #22
Dwellstream's Avatar
2012 27' FB International
Madison , Indiana
Hello Doug! Could you send the pictures again. I did not get them.
Stan
Dwellstream is offline   Reply With Quote
Old 11-18-2014, 01:13 PM   #23
Madison , Indiana
Never mind - here they are!
Old 11-21-2014, 09:56 AM   #24
Madison , Indiana
One fitting where the valve was patched with JB Weld & is holding so far, but the other is dripping water. The pump is off & the hose is disconnected. I assumed it was water left in the line and let it drip all night and it has not stopped. Any ideas where this is coming from?
Old 11-21-2014, 10:03 AM   #25
dznf0g's Avatar
Oswego , Illinois
May I suggest a long term fix for you, Doug? I would look into installing the same threaded fittings that your pump has and then installing the same brass valves that the AF bypass kits use. That way your valves will be up in the heated area and only "empty" lines will run outside. Although installation in the space you have will be patience testing, the valves are very compact, require only 1/4 turn to open and will be easy to open and close in the tight quarters.
-Rich-
Old 11-21-2014, 11:10 AM   #26
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
I noticed this year when I blew out the lines as I was winterizing that antifreeze came out. Apparently I forgot to open those drains when I dewinterized and I guess the RV antifreeze just sat in those low spots. Obviously we used and drank the water supply and had no taste or other ill effects. I wonder that if you use RV antifreeze when you winterize, it just might be better to not worry about opening those drains when you do your spring flush. It just might protect you if you get caught out in extreme temperatures.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
Fresh Water Low Point Drain on 2010 FC 28' kentuvman Plumbing - Systems & Fixtures 8 12-29-2012 08:37 PM
Replacing broken low point fresh water drain 2010 28' FC kentuvman Fresh Water Systems 0 12-28-2012 09:11 AM
How many low point drain valves on '08 23FB? bonginator Plumbing - Systems & Fixtures 6 10-01-2012 07:42 AM
Low point drain valves Gringo Fresh Water Systems 4 11-03-2011 09:13 AM
Replacing the low point water drain valves thecatsandi Fresh Water Systems 4 02-17-2009 11:32 AM
