Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Fresh Water Systems
Old 09-03-2017, 06:29 PM   #1
Bellevue , Washington
gunk in Fresh Water Tank - 2000 25C Safari
We did not use our trailer last year, and I must not have winterized properly (probably more than once in the last 17 years). I've been trying to get rid of small floaters. Sanitized with bleach and have drained the tank twice. today I filled it to the top and gave it a slight over pressurization with hose, so water streamed back out the fill port. The water looks like in the picture.
I'm thinking I need to have the tank replaced, unless there is help on cleaning it out.
WA_Safari is offline   Reply With Quote
Old 09-03-2017, 06:38 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Continue to clean, sanatize and rinse. Hopefully it will get all the gunk out.
MICHAEL
Old 09-03-2017, 06:43 PM   #3
Byron Center , Michigan
Fill it halfway, take it for a drive, drain it out the bottom and rinse another time or two?
YippieKiYa is offline   Reply With Quote
Shower drain gunk Ktholin Sinks, Showers & Toilets 7 06-21-2014 07:03 AM
Tank gunk -- help Zeppelinium Fresh Water Systems 17 06-17-2012 12:48 PM
Window gaskets 2000 Safari 25C A W Warn Leaks - Weatherstrips, Gaskets, Caulks & Sealants 4 03-15-2011 06:25 PM
25C 6 sleeper black tank Melvin P. Thorpe 2000 - 2004 Safari 15 10-14-2003 05:27 PM
sticky gunk norbert Our Community 7 08-17-2003 06:56 PM
