Old 05-20-2015, 06:37 PM   #1
Forger's Avatar
2011 25' FB Flying Cloud
Columbus , Indiana
Grumpy water pump
So, my water pump runs and shuts off as expected, but now, pretty frequently will not restart. The water pressure / flow goes to zero and the pump doesn't restart. When I turn the switch off and back on eventually, the pump starts and runs again. There's no pattern in playing with the switch and the pump responding. The pump itself feels pretty hot to me, but I never felt it when it had been running normally. Has anybody got any ideas regarding this, or should I just bite the bullet and replace the pump?
Bill & Martha
2011 25 Flying Cloud #525456
2010 F150 Lariat SCAB, 5.4L, 3.55:1
Forger is offline   Reply With Quote
Old 05-20-2015, 07:54 PM   #2
2019 27' Globetrotter
Missouri Valley , Iowa
The pump in my '02 Classic did a similar thing. It would shut off in the middle of a shower and usually in a minute or two would restart. Checking fuses and breakers didn't reveal a problem. I replaced the pump and the problem has not shown up again. I suspect the 12V pump motor would get hot and shut itself off. After cooling it would work again. A new pump was about $100.
Dan
Farmer Dan is offline   Reply With Quote
Old 05-21-2015, 07:23 AM   #3
A thermal overload switch will shut the pump off when it gets hot allowing it to restart in about a half an hour. If the pump gets hot in ordinary use, the motor is shot.
I agree replace the pump. $100 for a new pump is a cheap price to avoid aggravation. The pumps are easy to replace.
handn is offline   Reply With Quote
Old 05-21-2015, 07:55 AM   #4
KJRitchie's Avatar
2008 25' Classic
Full Time , Texas
I hope yours is easy to swap out. If I ever have to replace mine I'll need it to be the same make and model. Mine is buried under the refrigerator in a tangle of plumbing, heat ducting and wires. No room to refit the plumbing with new PEX fittings if I decided to replace with a different brand than my Aquajet that has the push in/locking connectors.
Kelvin
KJRitchie is offline   Reply With Quote
Old 05-30-2015, 01:23 PM   #5
Forger's Avatar
Columbus , Indiana
I swapped out the pump for the replacement model because the original model is obsolete. The replacement is 1 1/2 inches longer and just fit after drilling 2 new mounting holes. The new pump works like a dream and sounds very business-like.
Bill & Martha
Old 05-30-2015, 05:43 PM   #6
Regular Guy
NavyCorpsman's Avatar
1978 31' Sovereign
Hot Springs , Arkansas
I love a story that doesn't need a hammer and has a happy ending.
NavyCorpsman is offline   Reply With Quote
Hooked up water in winter and can't get water pump to pump water mrpettit Water Heaters, Filters & Pumps 9 08-11-2023 09:52 AM
Pump doesn't turn off and it doesn't pump water either. I don't know what to do! Melimelo Fresh Water Systems 10 05-25-2018 01:39 PM
air pump vs water pump kamo Water Heaters, Filters & Pumps 22 02-27-2008 02:01 PM
68 water pump-should the pump cycle? Boondocker Water Heaters, Filters & Pumps 8 08-06-2006 10:11 AM
