10-31-2005, 08:17 PM
Fresh water tank drain valve location?
I have a 76 Ambassador and need to winterize.
Does anyone have any hints on where the drain valve is located for the fresh water tank??
Thanks in advance
10-31-2005, 08:41 PM
San Angelo
Well, on my 71 Sovereign, the drain is located in the cabinet, where the heater is located, under the galley countertop....look there...I'm not sure how different the years and models were.
Frederic
Frederic
1971 Sovereign International - SOLD
2004 F-350 King Ranch
AIR # 8239
EX-WBCCI # 8371
11-01-2005, 03:15 AM
1977 25' Caravanner
Jeffersonville
, Kentucky
My 77 model has a plate on the belly pan with a drain valve coming out,the valve is in between the front axle and the front door.
Movie Stars and Film Crews come to Me from hundreds of miles enticed by My knowledge, My imagination,expertise, creativity and innovations!
11-01-2005, 03:52 AM
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County
, New Hampshire
I have 3 valves under the Galley in my 75 Trade Wind. Good luck
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
11-02-2005, 04:21 AM
thanks for the replies. I do have a metal access plate on the bottom ( in the middle) of my fresh water tank. When I took this plate off I can see the plastic holding tank. I also see electrical wires hooked up, this must be the water pump. I do not see a drain plug however? I have plumbing problems and some pipes are cracked so I can't use the pump method of draining. I may have to siphon?? I love my new (old!) Airstream but can't believe that they made this task so difficult
11-02-2005, 06:50 AM
1974 27' Overlander
1960 26' Overlander
Rockingham County
, New Hampshire
I found this im my '76 manual, see if this helps...
www.balrgn.com
11-02-2005, 07:20 AM
1977 31' Sovereign
1989 34' Excella
Johnsburg
My 77 31 foot Soveriegn does not seem to have a place to conviently drain the fresh water tank. I simply run the tank dry with the pump and then dump a gallon of anit-freeze in it to winterize. Works for me..
11-30-2005, 07:38 PM
Desert Fox
1985 31' Sovereign
Tucson
Drain
Hi All,
My 1985 Sovereigh has the drain valve in between driver side wheels. This is drain for potable water tank. It also has two drains in the back compartment for hot and cold water lines. So you can drain your hot water heater and your water lines.
Regards Russell
11-04-2007, 08:23 PM
2001 35' Land Yacht XL w/2 slides
San Jose
i found the hot and cold low water drains in compartment where I hook up water but cannot locate the actual fresh water drain for the whole freshwater tank--2001 Airstream Land Yacht 35.5 feet
