Old 11-19-2017, 02:33 PM   #1
Augianderson's Avatar
Louisville , Kentucky
ZipDee
N E 1 know where power switch is located on 2017 30' Classic?? Thanks Y'all !!
Augianderson is offline   Reply With Quote
Old 11-19-2017, 04:11 PM   #2
Retired.
. , At Large
Some of them didn't have power switches, just hit the "extend" or "retract" button. If yours is one that has the switch, it is located on the main control panel when you enter the trailer, on your left, at the end of the galley counter by the door.
Old 11-19-2017, 07:05 PM   #3
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
The control switches are part of the panel by the door. The board that does all the work is under the sink, behind the lowest drawer.
Old 11-20-2017, 08:06 AM   #4
Hi
Thank you Bob, I'll look there. Appreciate the help!!
Brad Anderson
Old 11-20-2017, 08:22 AM   #5
Has anyone manually cranked the power awning back on a 2017 Classic or similar set up? Can I simply turn the above referenced power switch off & then retract with the manual crack Airstream supplied? Thanks guys, appreciate the input--Brad
Old 11-20-2017, 08:22 AM   #6
crank---auto spell. :-(
Old 11-20-2017, 11:25 AM   #7
paiceman's Avatar
2020 28' Flying Cloud
Upper St Clair , Pennsylvania
You actually should have been supplied with some wires that will allow you to by-pass the circuit and switch, wiring directly to the battery and retract in that manner.
2020 28' Twin Flying Cloud
2021 F350 6.7 King Ranch
USAF Master Training Instructor (TI) & (MTI)- 68-72
Volunteer K9 Rehabilitator & Trainer
Old 11-21-2017, 05:53 AM   #8
OK thanks so much, I do have the wires but wasn't sure if switch still needed to be turned off.
Old 11-21-2017, 08:50 AM   #9
Half a Rivet Short
2022 Interstate 24X
Hi
There are instructions running around somewhere on how to plug the power cord into the motors. There also is a YouTube video showing some poor soul doing it.
Old 11-21-2017, 09:35 AM   #10
Yes Uncle Bob, I saw that video too which lead me to believe there was a switch on the circuit panel. Just trying to go out on the road prepared should/when the need arises. I'll post a good definitive answer once I get it. Know in the meantime I very much appreciate all of your suggestions/help.
R.I.P. ZipDee nettepdx Awnings 13 09-06-2005 11:08 AM
ZipDee Screen Room Install - anyone done it? grizzy 1997 - 2004 Bambi 9 09-25-2004 09:18 PM
Repair/Replace ZipDee Chair Fabric???? Tammy Upholstery, Blinds, Walls & Interior Finishes 3 08-01-2004 02:27 PM
How much should a 16ft ZipDee Awning cost? Silverfly Commercial Listings 3 07-13-2004 05:20 AM
