Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Awnings
Old 04-18-2015, 07:04 PM   #1
Houston , Texas
Awning jammed
91 Airstream Land Yacht. Awning will not retract completely, nor open. Any suggestions on what the issue may be? New owner and bought this as Xmas present for wifey, she's getting impatient.
Tlchorba is offline   Reply With Quote
Old 04-18-2015, 07:21 PM   #2
The Ice Man's Avatar
2011 27 FB International
Tucson , Arizona
Could be simple; could be hard. Simple = make sure the claw on the rafter bar is over the less diameter part of the step spacer. Unless it is, the awning won't close, but it should open. Hard = siezed bearings or broken spring.
The Ice Man is offline   Reply With Quote
Old 04-18-2015, 07:34 PM   #3
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Here's a video you can watch - not sure if this is the same on your 91. Good luck!
http://youtu.be/fLsKflCqhkY
Jammed Test Switch on Ventline dacantu General Repair Forum 0 03-25-2011 09:10 PM
Fix for door, screen door combination, jammed slider DaveFL Land Yacht/Legacy Motorhomes 0 11-05-2009 08:26 AM
zip dee main arm jammed Wayne&Sam Awnings 12 08-04-2007 04:17 PM
Need help with jammed electric jack! vintagemike Jacks, Stabilizers, Lifting and Leveling 6 07-31-2007 04:55 PM
Pantry Jammed dmac Cabinets, Counter Tops & Furnishings 1 03-10-2003 12:05 PM
