I should be receiving my new, yet vintage, pole & rope awning any day now. Our 65 Overlander, at some time, had a "c" channel awning rail, but has since been removed.
Any advice on what to use to prevent any water from entering under the awning rail when I attach it?
When you attach the new rail to the trailer use Vulkem sealant under it and butter the rivets before you install them and you should be good-to-go! Also, this would be a good time to pay attention to any old rivet holes up there from the previous rail. Get them filled so as to prevent inside wall leaks. Happy Trails, Ed
1967 Safari Twin "Landshark" w/International trim package
2014 GMC Sierra 1500 Double Cab SLE FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
At least as of last week, I found I could get both Vulken and TremPro at my local Fastenal. And of course, they also sell it at the Factory Store.
Yep! That's where I found both and cheaper priced than the factory store or RV centers. Ed
