Old 08-19-2017, 05:44 AM   #1
Fr Jeff
frjeff's Avatar
1989 29' Excella
Saginaw , Michigan
Propane Tank Cover
I have asked this before, without an answer:
Is the OEM propane tank cover aluminum or stainless? Magnets do not stick. And, is it gel coated form the factory?
Mine is a mess and I do not wish to spend big money on a new replacement.
Some PO removed the blue vinyl and adhesive, but must have tried to rub it all out with 80 grit sandpaper.
Need help here on attempting to make it presentable. Many thanks.
Fr. Jeff
2016 F150 Ecoboost
1989 Excella 29
frjeff is offline   Reply With Quote
Old 08-19-2017, 05:57 AM   #2
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
Mine is aluminum
Old 08-19-2017, 07:04 AM   #3
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
+1
Larry
lsbrodsky is offline   Reply With Quote
Old 08-19-2017, 07:34 AM   #4
centennialman's Avatar
2016 23' International
Centennial , Colorado
Aluminum
Steve "Centennial Man"
centennialman is offline   Reply With Quote
Old 08-19-2017, 10:02 AM   #5
Fr Jeff
frjeff's Avatar
1989 29' Excella
Saginaw , Michigan
Gel Coat??
Picture shows a definite line across the front of the cover (and it goes all around), exactly where the vinyl stopped.
I am presuming (being aluminum) that this was gel coated after the vinyl was installed.
Thus, I likely need to strip the gel and then attempt to polish.
Correct?
Fr. Jeff
2016 F150 Ecoboost
1989 Excella 29
Old 08-19-2017, 11:30 AM   #6
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Rivet Sort of...
Correct?
Attachment 292684
Well, yes and no.
Gel coat is used with fiberglass or other laminates during the molding process. It is the first coat into the mold and is the glossy surface you see. It doesn't have to be clear, it can be the finished color. White is especially popular on boats, for example.
For Airstreams, a clear coat is used. It is simply a coat of clear paint, like many cars now have a clear coat over paint to enhance the glossy finish. This is actually good news for you. Lots easier to remove than a gel coat.
The process is to clear coat the aluminum, then put the stickers on. Normally.
Yes, you will want to remove it before polishing. On a nearly 30 year old piece of aluminum it is nearing the end of its life anyway.
Actually, looking at your photo, the part that was undertone vinyl looks better than the rest. That's how mine would be if I took the vinyl off. The vinyl actually protects the clear coat. The sun is what really eats finishes. You probably have more and "better" clear coat there. Regardless, go down to clean aluminum and polish. You should be good.
You can find plenty of threads on polishing. You will see photos of trailers that look like your cover all the way down the sides. Doing the cover looks like a good learning experience. Everything you need to learn in miniature.
Vaughan
Old 08-19-2017, 11:33 AM   #7
Fr Jeff
frjeff's Avatar
1989 29' Excella
Saginaw , Michigan
Propane Tank Cover
Vswingfield - My gratitude. I'll likely use Citri Strip as I understand it can be power washed off (not scraped).
Fr. Jeff
2016 F150 Ecoboost
1989 Excella 29
Old 08-19-2017, 11:41 AM   #8
1983 34' Excella
1967 24' Tradewind
Images: 32
Thumbs up Sounds Good
I think you're on the right track. Aluminum is delicate and any scratch you don't put in is one you don't have to polish out.
There are plastic scrapers available that will reduce your chances of scratching the surface if you encounter really tough spots. I would try multiple applications of stripper first. Taking your time can actually save you time in the long run.
Keep us posted on your progress.
Vaughan
Old 08-20-2017, 12:37 PM   #9
Georgia Rolling Stone's!
2018 25' International
Peachtree City , Georgia
Propane Cover for sale
Hello,
I have an extra propane cover that I will sell you. When I purchased my 2012 FC, 25' the previous owner went out and purchased a new one because the original had a small dent. I would be happy to snap a picture and send it you.
Its still in the box just sitting in my garage. There really is nothing wrong with this except a small dent. Let me know.
A.H. Stone
ahstonejr@gmail.com
hstone is offline   Reply With Quote
Propane tank cover walter1 LP Gas, Piping, Tanks & Regulators 9 03-14-2007 11:08 PM
Need propane tank cover and front rock guard! cobra93 Rock Guards, Segment & Window Protectors 8 08-11-2006 10:10 PM
Propane Tank Cover tmeagle1 LP Gas, Piping, Tanks & Regulators 6 03-04-2004 07:30 PM
Propane tank cover.... drboyd LP Gas, Piping, Tanks & Regulators 2 07-29-2003 03:42 PM
Propane Tank Cover 74SovereignInt. LP Gas, Piping, Tanks & Regulators 13 02-27-2003 10:37 AM
