Permacote is a beautiful finish. Cayo cleans the trailer first with Comet cleanser and then washes the trailer with lacquer thinner. Never use steel wool on aluminum. It will turn it black in time from microscopic pieces of embedded steel. Always use aluminum wool on aluminum.
1966 28' Ambassador
Mobile
, Alabama
I'm pretty sure the acid will remove the annoization. I've heard people recommend using Bon Ami (a mild comet) to clean and get the worst of the oxidation off and then covering with finish (wax, flood, etc). That is my plan but I haven't had to time to get to it yet.
The acid wash should remove the oxidation from the aluminum, but keep in mind the finish will look much different. I believe people call it a satin look. If you decide to polish it will help a bit.
