11-24-2014, 04:13 PM
1964 24' Tradewind
Palatine
How does this come off?
Before stopping for the season, I tried to see how well my 63 Tradewind would polish. I removed one of the clearance lights and tried several polishes. Then I tried acetone, paint stripper, paint thinner even gasoline. Next, I decided to try you guys .... How does this come off? BTW I am referring to the black gook around the light. All the lights have them, some streaking down several inches.
11-24-2014, 04:20 PM
1968 22' Safari
Buda
Goof off pro strength
DFlores
David & Diana
11-28-2014, 08:07 AM
The Sign Lady
1969 23' Safari
1974 Argosy 22
1964 24' Tradewind
Victoria
, British Columbia
If it is old vulkem or silicone based (which is a no no on aluminum) I would recommend rapid remover. It is an industrial strength adhesive remover I use at my sign shop to remove the adhesive left behind after removing vinyl lettering. So far in my shell on restoration have used half a gallon to remove 40 plus years of goo easily.
I have discovered it does not remove gutter seal or cured sitkaflex (Works great on fresh uncured sitkaflex though) all the older goop on my trailer came off no problem
If you are unsure of what your old goop is call around to a few sign shops near you and see if they use rapid remover and if they do, ask to borrow a small jar of it to see if it works on your goo before you order some.
Spray it on, leave 60 seconds if an area starts to look dry spray some more, scape off the goo with a plastic scraper into a paper towel, repeat as needed, use a paper towel soaked in the stuff to buff any residue off. It also removes sap spots from the roof and de-stickifies gucky interior vinyl walls. Clear coat safe we use it on vehicles and aluminum work trailers all the time.
Good luck,
Leya
11-28-2014, 12:13 PM
1966 26' Overlander
Woodstock
, Georgia
what she said. That black is where the aluminum oxide has gotten into the sealant. This is why you strip the clearcoat, then compound, then polish and then lastly reseal all the seams and lights,etc.
11-30-2014, 09:44 AM
1964 24' Tradewind
Palatine
Thank you, everybody! I will try all of it. The goof off first, as the Mrs. has it under the kitchen sink. I can only guess what that stuff is? I have seen it in a lot in the "before photos" in this forum. So..I am confident it comes off. Again, Thanks, Ed
12-10-2014, 12:57 PM
1964 24' Tradewind
Palatine
We had a warmer day in Chicago the other day so i tried Goof off on that black stuff. The black stuff LAUGHED at Goof off. Nothing happened. It looks like it is "in the metal"
as ALENSD said in his thread. Come spring, I'll try some of the strippers mentioned in this forum.
12-10-2014, 01:17 PM
1967 17' Caravel
Pocatello
, Idaho
Good luck,
Leya
Sign lady,
Interior: does this stuff remove the sticky residue left on the luan bulkheads when the "wallpaper" peels off a '70s unit? And if it removes the sticky, how do you get the remover residue off so you can finish the luan with varnish, or paint, or whatever? I don't want to end up with worse residue to get off than I started with.
Hope you can help!
Vivian
12-11-2014, 08:05 AM
The Sign Lady
1969 23' Safari
1974 Argosy 22
1964 24' Tradewind
Victoria
, British Columbia
I honestly have never tried the Rapid Remover on a raw wood product so I am not sure how it would work. I would suspect it wouldn't work to well, some problems I could envision would be the spray would suck in the wood and not work so much on softening the glue. Or it may soften the glue but scraping it off after could be ugly as your scraper would only scrap from the high level areas and all the indenty areas like the texture of the wood or knots or other imperfections would be reservoirs for the goo to collect and wiping with paper towels after I could see the paper towel breaking apart and sticking to the wood. You could always try a small area and see what happens though...
12-11-2014, 10:14 PM
1967 17' Caravel
Pocatello
, Idaho
I'll have to try it on a small, out-of-sight section: you are right. Maybe using 0000 steel wool instead of paper towels, as you would for paint or varnish removal, would be a better plan? The luan is free of knots; I sure hope this will work.
Thanks muchly!
Vivian
12-12-2014, 12:43 AM
1962 19' Globetrotter
1963 19' Globetrotter
1961 19' Globetrotter
Wheat Ridge
The brown is not anything on the surface rather it is in the Aluminum. The steel screws that holds down the light base to the Alclad skin has caused this color change. It is caused by dissimilar metals when one metal eats into the other. You need to replace these screws with stainless, but if it was my project I would personally rivet the three holes then use stainless screws. You need to remove the three screws and remove the base plate to remove the rust off the Aluminum. You will have to mechanically remove the rust down to where you see fresh shinny Aluminum. Looking at your picture shows deep pitting in your alclad aluminum anyways so to remove down to bare aluminum is not going to hurt you much. I would start with F9 and if that does not cut through the rust you may have to DA with scotch bright. I would seal up the light base plate and rivet it bak into place and it should turn out real nice.
www.VINSTREAM.com
Wheat Ridge, Colorado
WBCCI # 1962
Instagram #Vinstream
12-14-2014, 01:02 PM
The Sign Lady
1969 23' Safari
1974 Argosy 22
1964 24' Tradewind
Victoria
, British Columbia
Oh, good idea Vivian, I could totally see that working OK :-)
Good Luck and keep us posted on how it works
