Yep, polybutylene lost and PEX won. Older Airstreams were plumbed in polyb, including my 86.
And my 86 developed a plumbing leak just where yours did. I wonder if the two valves in the photos are "low point drains", but usually there are three "low point drain" valves. I bet the fresh water tank is under the floor somewhere close by.
Chapter 1: My leak showed itself the day before our planned trip of course. I dried it, cleaned it with alcohol, and slobbered two part epoxy on the offending valve and joint. My leak was on the
12v pump circuit, not the city water circuit. It worked! The next morning we hitched up and left.
Chapter 2: My repair held for two years and 10,000 miles. But it started leaking again this summer. I just finished taking the fresh water tank down, and replacing all the polyb plumbing under the floor and to the kitchen sink and from the bathroom. Big job, but no more leaks. I left out the "low point drains" as I am a air pressure blow and then install RV antifreeze winterizer. I never found the drains very effective and don't trust them to get all the water out. But I do trust all the extra joints for the drains to leak someday. Less joints, less leaks.
So try some epoxy and see if you can smear some into the offending leak. And have nightmares about a big plumbing job coming up.
The photo is my leaker with epoxy after I removed it from the trailer. The other photo shows the three valves under the galley cabinet. No room to work.
David
