Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > General Repair Forum
Old 06-02-2014, 06:26 PM   #1
Winder , Georgia
Toilet flange won't come off!!! Need help
Having trouble removing the old toilet flange. Honestly I don't need to totally remove it, just turn it 90 degrees to fit the new toilet. I know there have been other threads about this, but I can't seem to find one. Any help would be greatly appreciated!!
blackhawksid is offline   Reply With Quote
Old 06-02-2014, 07:31 PM   #2
Bigventure's Avatar
2016 30' Classic
Hinckley , Ohio
Well use a heat gun or blow dryer can be used to warm it a bit and get the old pipe dope to soften. A couple of toilet closet bolts with nuts and washers in the flange, then a piece of 2x4 between the bolts to turn it slowly. I would losen it rather than tighten it. (turn it counter clock wise)
My budget won't stop me from buying something online that I don't need, but the threat of getting promotional
emails every day for the rest of my life just might!
Bigventure is offline   Reply With Quote
Old 06-02-2014, 07:35 PM   #3
Winder , Georgia
Thanks a bunch bigventure- I'll give this a try this week!
Old 06-02-2014, 08:34 PM   #4
1970 27' Overlander
1970 21' Globetrotter
Hamilton , Montana
I have a 1970 GT and the flange turns but doesnt come out. Would this be glued in?
gdod25 is offline   Reply With Quote
Old 06-02-2014, 09:07 PM   #5
1970 27' Overlander
Hamilton , Montana
I should have said the outer ring turns but the inner black does not.
Old 06-02-2014, 10:36 PM   #6
Zeppelinium's Avatar
1973 23' Safari
1977 23' Safari
2018 25' Flying Cloud
Palmer Lake , Colorado
The flange is screwed (threaded) into the tank. The outer flange turns in order to align the bolts with the toilet. You have to unscrew the inner flange. Note that there are two 1/4" slots at the outer edge of the inner flange. You need to make a tool just wide enough to get in those slots, then you can turn it to screw it out.
Zep
Zep@Charmedquark.net
Old 06-02-2014, 10:47 PM   #7
Tom O
Toldfield's Avatar
1966 17' Caravel
Altadena , California
I had the same problem and used a strap wrench. With a bit of effort I was able to back it out.
"Badges? We ain't got no badges. We don't need no badges. I don't have to show you any stinking badges!"
CA-7
Toldfield is offline   Reply With Quote
Old 06-09-2014, 11:11 AM   #8
Winder , Georgia
2x4 method worked like a champ. New toilet installed, complete with a shut off valve. Thanks for all the help and replies!! I'll post pictures soon...
Need some quick help with toilet flange aquinob General Repair Forum 4 01-10-2013 01:47 PM
Turned off fridge to defrost, won't come on w/elec., will with gas BrianD. Refrigerators 20 12-13-2010 12:02 PM
Toilet donut won't come off steven2themax Sinks, Showers & Toilets 8 11-09-2010 04:28 PM
Black Tank-To Flange or not to Flange? Mrwaterway Waste Systems, Tanks & Totes 4 12-02-2009 09:02 AM
Toilet Flange won't unscrew!! mello mike Sinks, Showers & Toilets 11 07-11-2005 08:34 PM
