Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > General Repair Forum
Old 07-24-2014, 02:15 PM   #1
keithgregg's Avatar
1970 23' Safari
Hazeltucky , Michigan
Stink pipe covers for 1970 Safari
I recently purchased a 1970 23ft Airstream Safari. What I can only think of as the stink pipe outlets coming out of the roof are just bare black pvc with some sheet metal and goo loosely fitted around them. There doesn't seem to be any major leakage but I do need to address this. Does anybody have tips on how to finish this off properly? Maybe some decent pics or links to where to buy replacement parts. I am new to rvs and this is my first of many questions.
Peace and thanks for the help.
keithgregg is offline   Reply With Quote
Old 07-24-2014, 02:23 PM   #2
1981 31' Excella II
New Market , Alabama
This should work.
Metal Roof Pipe Cover
Perry
Old 07-24-2014, 03:00 PM   #3
keithgregg's Avatar
1970 23' Safari
Awesome. Thanks for the rapid reply. This should do the trick.
Old 07-24-2014, 03:16 PM   #4
keithgregg's Avatar
1970 23' Safari
I just went to inspect for a fit and I was wrong. No sheet metal there, just a square of brittle cracked yellow plastic and a mess of butyl tape. These should work fine once I clean all the mess off the roof. I guess I should seal the new caps with butyl tape. I'll also have to fill the old screw holes. I was going to use clear silicone. Good thing or bad thing?
Old 07-24-2014, 05:16 PM   #5
1981 31' Excella II
I would use Trempro-635 or some other urethane based caulk. I don't like tape. I have see the stuff gap and leak over time.
Perry
Old 07-24-2014, 06:08 PM   #6
keithgregg's Avatar
1970 23' Safari
I had bought some 50 year clear architectural grade silicone from ACE Hardwarebthe other day to start sealing up leaks. It says on the label that it is good for aluminum. Should I not use this? I'm not trying to doubt you. I'm just ignorant on the subject.
Old 07-24-2014, 06:16 PM   #7
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
The biggest issue with silicone is once you use it nothing else will stick until you clean ALL the residue off, this is not as much of a problem with the urethane based sealants. Trempro is a better choice IMHO.
Aaron
WBCCI #XXXX AIR #2495
Old 07-24-2014, 06:19 PM   #8
2005 19' Safari
GLENDALE , AZ
Some time ago, Lewster recommended the following:
"SikaFlex 715 is a great, self-levelling roofing sealant for things like Fantastic fans, tank vent caps and other thru-roof penetrations."
"If you are looking for seam and/or window sealing, then SikaFkex 221 in grey is what you need. Also, the Airstream factory uses a product called Acryl-R for wicking into outer seams as well."
Invasion of the Stink Bug. urnmor Winterizing, Storage, Carports & Covers 34 10-12-2016 05:59 AM
Orig.Vent Pipe Covers - Still Available? Creampuff Roof Vents, Skylights & Fans 2 07-24-2014 05:50 PM
My Argosy side mirors stink! Replacements? ViewRVs Argosy Motorhomes 8 10-22-2012 05:05 PM
sulfur stink howco General Repair Forum 9 04-13-2012 05:35 PM
Stink in '74 Overlander!!!!! silverdaddy General Repair Forum 6 10-04-2009 01:47 PM
